Why does my Mits RP TV keep resetting the contrast?
trubluluc
I have set and reset the F*#!ing contrast to midway a half dozen times in the setup.
A couple months will go by, and I start to see the ghosting of white titles on a black background,
so I check the contrast...and sure as hell the damn tv has reset itself to maximum contrast again.
It's a Mitsubishi diamond series 55"
Anyone else have this situation?
A cure?
-Luc
A cure?
-Luc
No, could you pissibly loosing power temporarily and the tv resetting itself to it's default state?
Yes, I definitely get momentary power outages.
I don't understand why full contrast would be the default setting,
as it looks like crap, and can't be good for the TV.
-Luc -
Don't click on the "picture modes", they will reset your settings.
