popping sound
demt1992
Has anyone gotten an answer or resolution to the popping subwoofer from Polk? How do I update the software version on google home?
Answers
Usually firmware updates are done via the Internet. What system are you referring to?
Polk Audio Magnifi.
A cause of that kind of issue is interference with other wireless devices. As a test can you move your router as far away as possible from the soundbar and see if the popping stops?
