Can I use XLR cable with RCA adapters
I recently changed amps and my new one isn't a balanced design. I've got a really nice pair of Wireworld Gold Eclipse XLR's so can I just use XLR to RCA adapters on each end and use it for my DAC RCA to amp RCA connections?
    Clipdat Posts: 13,101
    Sure but for the amount that you'll spend on quality adaptors that don't degrade the signal (Cardas, etc) you'll be better off just getting some different ICs.
  • dragon1952
    dragon1952 Posts: 4,939
    edited December 2022
    Well the equivalent Wireworld RCA cables are over $1K so I thought I'd try it first and see. I just wanted to make sure it would work with an adapter on both ends. You really think something like this would degrade the signal? A lot of cable companies seem to use Neutrik connectors.
    https://www.neutrik.com/en/product/na2mpmm
    Those would absolutely degrade the performance of your WW XLRs.
    https://www.thecableco.com/catalogsearch/result/?q=cardas+xlr+rca&cat=
    Even these arguably might and you're looking at $400 worth of adaptors.
    mhardy6647 Posts: 35,416
    You can, but why would you?
    No value added, indeed, the value of balanced I/O is lost.
  • invalid
    invalid Posts: 1,553
    Jenson transformer would be half as much as new wireworld cables, $499
  • jdjohn
    jdjohn Posts: 3,416
    Tough crowd. The 'cable', of course, is still fine, but the added hand-off connections on the ends are compromised. How much will it truly impact the sound? Only the listener can answer.
    Here is a rather radical thought: if you have enough cable length to spare, you could de-solder the XLR plugs, trim the exposed conductors by a half-inch or so, and then install some high-quality, locking, RCA plugs. Later, again, if there's enough length, you could later re-install the XLR plugs, if needed.
    Great way to take the value of the XLRs from $1k down to zero.
  • jbreezy5
    jbreezy5 Posts: 1,141
    Doesn’t hurt to try if you just want to experiment. True, you won’t be balanced anymore; true xlr-to-rca adapters probably don’t have fancy metallurgy; however, for small outlay you can find out how it actually sounds and report back your impressions.
    I had to do this when I was running 2.2 using an Arcam a75+ as preamp (rca) into driverack pa+ EQ/crossover (balanced) into b&k 125.2 for main speakers and crown amp into dual SVS cylinder subs; both amps balanced.
    Sounded darn good.
    Worst case scenario, you could return the adapters.
  • jdjohn
    jdjohn Posts: 3,416
    Clipdat wrote: »
    How are you defining 'XLRs'? The raw cable, the plugs? If you plan to keep both pieces indefinitely, then who cares about 'value'? I guess the implication is that the individual parts are worth less than the whole.
    I have a very different perspective on cables, since I typically roll make my own.
    F1nut Posts: 52,182
    I don't see a problem.
  • dragon1952
    The thing is the XLR and RCA version of this cable is identical material and geometry-wise. The only difference is the connectors. I can no longer use XLR as my amp isn't balanced but maybe I can retain the sonic signature of the cable, or most of it? I got a really good deal on these cables and I can't afford the $1k to get the real RCA version.
    If you are sure you aren't going to be needing those XLRs anymore then you can sell them and get the RCA version. Or buy from a place that allows you to trade in/up, I'm sure they will accommodate you and make you a deal.
    I just don't think it's worth it to be putting money into adapters that won't serve your aural bottom line.
    Contact Skip at Audio Thesis, he's still a WW dealer. He should be able to help you out.
    Alternatively you could always send them in to WW to be re-terminated.
  • dragon1952
    The re-termination might be a good option....never thought of that. As far as selling you know how that goes. I could probably get half of what I'd need to replace :^ / I'm going to check on the re-termination idea.
    Cool, let us know what you find out from WW.
    Always preferable to factory re-terminate with official invoice/documentation, versus doing it yourself with off the shelf connectors - specifically in terms of resale value and overall quality.
    Again, just my opinion.
    msg Posts: 10,562
    you could try it with adapters from an easy returns place like Amazon and see what you think. I just saw some Cardas ones for $120. see what you think. then you still have your WW RCAs for when you realize you don't like your new amp? :D
    https://www.amazon.com/Cardas-Audio-Male-Adapters-MRCA-MXLR/dp/B00VMVJ6K6
    dragon1952 wrote: »
    ahh, OK. Got it.
    Doesn't hurt to try, although the XLR cable won't be identical to the unbalanced cable, by definition.
  • dragon1952
    Wireworld wants $350 for re-termination. That wouldn't include shipping of course :^ / I could sell mine and buy the RCA version for that.
    VR3 Posts: 29,636
    Drill a hole in your amp and install xlr jacks
    dragon1952 wrote: »
    Wow that's excessive. I wasn't expecting the re-termination service to be that expensive.
    audioluvr Posts: 6,016
    Ya the WW ends are spendy being that they are silver coated OFC copper terminals. I was going to do my own but because of the intricate design of their wiring I chose to just cough up the money and have them do it. If you want to give it a go though I still have the terminal ends somewhere.
    F1nut Posts: 52,182
    pitdogg2 Posts: 27,618
    Green tax... WTF?
  • jdjohn
    jdjohn Posts: 3,416
    Clipdat wrote: »
    dragon1952 wrote: »
    A little naive of you, Drew.
    F1nut Posts: 52,182
    Green tax... WTF?
    Coming to the USA soon no doubt.
  • jdjohn
    jdjohn Posts: 3,416
    Green tax... WTF?
    Pucker-up, butter-cup.
    jdjohn wrote: »
    Really, Jody? Naive?
    I just inquired with Audioquest on how much it would cost to factory re-terminate a pair of Yukon XLRs to RCA connectors - they use similar silver plated connectors and it was quoted as $160- so $190 less that Wireworld charges.
    So me being surprised at Wireworld's re-termination fee isn't being "naive" at all, it's actually justified since their price is over double that of what Audioquest charges.
    "From: Dustin Cairns <dcairns@audioquest.com>
    Sent: Thursday, December 8, 2022 4:57 PM
    To: Drew
    Cc: Peter den Haan <pdenhaan@audioquest.nl>
    Subject: RE: Re-termination for Yukon XLRs
    Hello Drew,
    To re-terminate all ends of a pair of Yukon XLR’s to RCA’s would be $160. I have attached our return authorization form, just follow the instructions below to obtain a RMA number for the re-termination."
    VR3 Posts: 29,636
    Wire world uses ambidextrous technicians, this allows them to terminate each end with appropriate left and right hands... This generates a more pure sound transmission.
    I am sure you can appreciate how costly it is to find an ambidextrous technician with appropriate skills.
  • jdjohn
    jdjohn Posts: 3,416
    "Naive" was perhaps a poor choice of words on my part, but we shouldn't be surprised that the cost to re-terminate a $1,000 cable is about double the cost for re-terminating a $500 cable. I agree that it is excessive, but again, not surprising.
    Btw, I am an ambidextrous solderer. Maybe I could get some part-time work with WireWorld.
  • rebelsoul
    msg wrote: »
    I would try these first. Not a huge investment and Amazon easy return policy
    VR3 Posts: 29,636
    If you do use those adapters you need to support the connectors coming off the amplifier as that will cause alot of pressure on the rca jack and they are not really designed to have that much weight hanging off the end
