Subwoofer to pair with my Snell CV speakers
I have been considering adding a subwoofer to my two channel system. My speakers are Snell Acoustic C/V. I was studying the nearfield frequency measurements I found on Streophile, and it looks like a sub would fill in the bottom end where these speakers roll off.
My budget would be under $1500 for the sub and I'm not opposed to buying used. I do not want a high gloss finish, but I would like wood grain if possible. My room is 10 feet wide by 17 feet with 8 foot ceiling. I'm looking for suggestions.
    Clipdat Posts: 13,100
    Does your preamp have a sub out or how are you planning on doing the bass management/integration?
  • I would have to use the speaker level inputs. The preamp does not have sub out.
  • tratliff
    tratliff Posts: 1,807
    Take a look at Rythmik.
    VR3 Posts: 29,521
    Rythmik makes good subs
    F1nut Posts: 51,924
    For your budget, Rythmik.
  • Seems like a concensus. Thanks!
    F1nut Posts: 51,924
    edited December 2022
    It's hard to beat servo subs, which Rythmik are. I would have recommended Velodyne, but their servo subs are a lot more money.
  • rooftop59
    rooftop59 Posts: 8,120
    On the used market Martin Logan is hard to beat. Grotto, descent, depth, all sealed servo subs. I had the Grotto and it was one of the most musical subs I’ve owned, and I’ve had a few over the years 😂
    Game Room 5.1.4:
    Bedroom 2.1
    treitz3 Posts: 20,069
    It's hard to beat servo subs <snip>
    Spot on.
  • jbreezy5
    jbreezy5 Posts: 1,141
    @newbie308…
    Do not purchase a sub, instead send those Snells my way; I will take the sub-matching burden off your hands.
    txcoastal1 Posts: 13,518
    jbreezy5 wrote: »
    @newbie308…
    I always wanted to hear these Snell Illusion loudspeakers...Joseph D'Appolito was the designer....hubba hubba
  • txcoastal1 wrote: »
    jbreezy5 wrote: »
    @newbie308…
    There's someone selling a pair of those within an hour's drive from me for $10k. I'm not a fan of the piano black though. I don't have the time to be constantly dusting my speakers.
    newbie308 wrote: »
    I dust my speakers, my rack, and all of my components with a soft microfiber towel before every listen. :)
  • Clipdat wrote: »
    I dust mine once every five years whether they need it or not... :D
