Center channel speaker upgrade
French_guy
in Speakers
I have 2 x RTi A5 and the CSi A4 for the center
I would like to upgrade the center. I know I should ideally go with the CSiA6, but I can't find it (new or used)
What would be a good upgrade, but still matching my RTiA5?
RTiA5 + CSiA4 + Jamo SW410E
Yamaha TSR-700 (equivalent to RX V6A)
No surround...yet
No surround...yet
Yes CSiA6 was part of the same series.
CSi5 would also be fine. What AVR do you have? Might be able to go back to a cs400i or up to a reserve or legend series if you have a good auto eq setup.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
It's the Yamaha TSR-700RTiA5 + CSiA4 + Jamo SW410E
No surround...yet -
I would stay in the hunt for a CSiA6, is a really good center channel. While waiting, have you manually adjusted the CSiA4 in settings?2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I feel what's coming from the center channel (dialogues) is usually weak. So I need to raise the main volume, but when action scenes come, it's way too loud.
I ran YPAO, but it still doesn't "sound right". I did try to boost the center channel, but I had to put +10 dB to have the feeling that dialogues were OK
So I thought (maybe I'm wrong though) that a better center speaker (CSi5 or CSiA6) would sound much better......
How should I use a sound level meter (I guess I can buy one on Amazon)?RTiA5 + CSiA4 + Jamo SW410E
No surround...yet -
YPAO shows the levels and distances. You can also do test tones. He needs to check these.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
