Center channel speaker upgrade
I have 2 x RTi A5 and the CSi A4 for the center
I would like to upgrade the center. I know I should ideally go with the CSiA6, but I can't find it (new or used)
What would be a good upgrade, but still matching my RTiA5?
RTiA5 + CSiA4 + Jamo SW410E
Yamaha TSR-700 (equivalent to RX V6A)
No surround...yet
    pitdogg2 Posts: 27,659
    Yes CSiA6 was part of the same series.
  • rooftop59
    rooftop59 Posts: 8,120
    CSi5 would also be fine. What AVR do you have? Might be able to go back to a cs400i or up to a reserve or legend series if you have a good auto eq setup.
    Game Room 5.1.4:
    Bedroom 2.1
  • French_guy
    rooftop59 wrote: »
    It's the Yamaha TSR-700
    No surround...yet
    txcoastal1 Posts: 13,519
    I would stay in the hunt for a CSiA6, is a really good center channel. While waiting, have you manually adjusted the CSiA4 in settings?
  • French_guy
    I feel what's coming from the center channel (dialogues) is usually weak. So I need to raise the main volume, but when action scenes come, it's way too loud.
    I ran YPAO, but it still doesn't "sound right". I did try to boost the center channel, but I had to put +10 dB to have the feeling that dialogues were OK
    So I thought (maybe I'm wrong though) that a better center speaker (CSi5 or CSiA6) would sound much better......
    How should I use a sound level meter (I guess I can buy one on Amazon)?
    No surround...yet
  • Milito
    Milito Posts: 2,003
    YPAO shows the levels and distances. You can also do test tones. He needs to check these.
