Polk SDA 2 issue
warlocks1
The left speaker’s SDA drivers are not moving. Right side is fine
How do I trouble shoot?
Answers
Which SDA 2
Test tone for left speaker will drive SDA driver on right channel, test tone on right speaker does not drive driver on left speaker.
Should I start by swapping the drivers? -
Driver magnet has shifted.Political Correctness'.........defined
President of Club Polk -
Jesse, i swapped drivers and it’s not the driver.
Still wouldn’t drive left SDA effect. Right still worked
Thanks -
Ok, I assumed by not moving you meant the driver was locked up when pushed on by hand. Obviously, I was mistaken.
So, the SDA driver is not getting a signal. That could be an issue with the SDA cable or the SDA socket or the crossover or the lead wires coming off the crossover.
