Polk SDA 2 issue
warlocks1
warlocks1 Posts: 1,284
edited November 2022 in Vintage Speakers
The left speaker’s SDA drivers are not moving. Right side is fine
How do I trouble shoot?
Answers
  • warlocks1
    Test tone for left speaker will drive SDA driver on right channel, test tone on right speaker does not drive driver on left speaker.
    Should I start by swapping the drivers?
    F1nut Posts: 52,011
    Driver magnet has shifted.
  • warlocks1
    Jesse, i swapped drivers and it’s not the driver.
    Still wouldn’t drive left SDA effect. Right still worked
    F1nut Posts: 52,011
    Ok, I assumed by not moving you meant the driver was locked up when pushed on by hand. Obviously, I was mistaken.
    So, the SDA driver is not getting a signal. That could be an issue with the SDA cable or the SDA socket or the crossover or the lead wires coming off the crossover.
