Monitor 11 crossover question
Just picked up a pair of monitor 11s . They are in bad shape but a good winter project. Strip vinyl and re-veneer...among other things. Would like to replace the binding posts...just wondering how to pull the crossover apart...thought I would ask before I break something.
Answers
    pitdogg2 Posts: 27,576
    XO should be on the binding post cup. Pull out the cup after you remove and document the wires on the midwoofers. You'll need to remove the XO from the stand-offs on the cup to get to the binding post.
    Report back once you see all the glue we'll go from there.
  • gjmess
    gjmess Posts: 15
    So I removed the crossover from the spools....now I have two spools of inductors but still no access to the binding posts.
  • Gardenstater
    Gardenstater Posts: 4,858
    I think you're going to have to push the center pins back on those expandable white nylon rivets and then you will gain access to the binding posts.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • gjmess
    gjmess Posts: 15
    That's what I was thinking....easier said than done. Off we go.....
  • gjmess
    gjmess Posts: 15
    FYI....yep. What a pain. Whose idea was that? :)
