Built in Ceiling Speakers
Tony_Barton
Several years ago I bought ten RC60i in-ceiling speakers. I had an installer wire them up to my tuner in 4 different rooms in my house through wall mounted adjustable volume controllers.
So now I want to hook up the remaining two through one volume controller in another room but I do not know which type of volume controller to buy and the original installer has long gone out of business.
Does anyone have any ideas or can suggest the type of volume controller to buy for this type of Polk speaker? Any help would be greatly appreciated. By the way I am in Canada so not sure what difference that would be to obtaining the volume controllers.
I remember that there was a concern about the impedance but I can't remember what it was.
Answers
Pull one from the wall and look for names and part numbers. If you cannot do that, I would leave doing that work to a professional.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I did try that but the manufacturer of the volume controller has also gone out of production!!!
I always felt the Niles level controls were the best.
Who is the maker and what is the part number?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Thanks everyone for your help.
