Built in Ceiling Speakers
Several years ago I bought ten RC60i in-ceiling speakers. I had an installer wire them up to my tuner in 4 different rooms in my house through wall mounted adjustable volume controllers.
So now I want to hook up the remaining two through one volume controller in another room but I do not know which type of volume controller to buy and the original installer has long gone out of business.
Does anyone have any ideas or can suggest the type of volume controller to buy for this type of Polk speaker? Any help would be greatly appreciated. By the way I am in Canada so not sure what difference that would be to obtaining the volume controllers.
I remember that there was a concern about the impedance but I can't remember what it was.
Answers
    nooshinjohn Posts: 26,101
    Pull one from the wall and look for names and part numbers. If you cannot do that, I would leave doing that work to a professional.
  • Tony_Barton
    I did try that but the manufacturer of the volume controller has also gone out of production!!!
  • SeleniumFalcon
    I always felt the Niles level controls were the best.
    Who is the maker and what is the part number?
  • Tony_Barton
    Thanks everyone for your help.
