Windows 11
Anyone tried this yet? Impressions?
    SCompRacer Posts: 9,408
    edited October 2021
    I'm just a basic user so don't expect too much from me. ;) I have it on my fairy new Dell laptop with Intel Iris XE Max graphics. It arrived with Win 10 and upgraded to Win 11. At first glance it seems like just a more polished presentation with rounded corners and things moved around. Your start menu at left side lower corner is gone, though IIRC you can change that. Start button defaults to center of screen in the lower taskbar.
    After my Dell "upgraded" to Win 11, the Start button wouldn't work. When I clicked on it, most of the time nothing happened. If it did appear, it was there and gone in a micro second. This made it difficult to access programs, I had to perform a Search for them. Dell support said we don't know. No answers at Microsoft. Then an Internet search led me to an obscure post at some forum where someone said they removed the Intel Iris XE graphics from device manager and rebooted, then the start menu would appear and remain.
    That fixed the start menu issue but created another. When I have a browser opened and get a message from Eset virus scan, the icon and print are so tiny you need a magnifying glass to read it. I can magnify the browser page, but the icon remains tiny. I haven't looked into how to fix that yet...
    gudnoyez Posts: 8,232
    Hopefully all my USB dacs run on it when the time comes, another upgrade enough already.
  • Willow
    Willow Posts: 11,371
    A fairy computer? I'm sure there is a support group for that....
    mhardy6647 Posts: 35,562
    SCompRacer wrote: »
    Lordy, but I love technology -- especially for its own sake. :/
    As Dr. Zachary Smith would've put it:
    Willow wrote: »
    I'm told it's all about inclusion these days....
    :D:D
  • sucks2beme
    sucks2beme Posts: 5,703
    Seems every other windows release is awful.
    I'm holding out for a while
    pitdogg2 Posts: 27,918
    If ya'll ain't noticed every other windows OS software is a pig.
    Wait for the next one😉
    Yup, and it was true for some revs of MS/DOS, too, as many of the crustier denizens of this forum may recall :#
    txcoastal1 Posts: 13,520
    In August I finally received my MSI Tiamat with extra goodies back ordered since February
    Anyway my IT support team has been beating up 11 for almost a year
    I have 10 pro, and they said my machine will love 11. These guys are old hackers.
    I'm old and may check out before 12. :o
  • mrbigbluelight
    I look back with fondness on Windows ME.
    Of course. I look back with fondness on the day I got married.
    Both wound up with about the same level of functionality and aggravation. 🤯
    SCompRacer wrote: »
    I mean, you should hold on 'til Lucky Thirteen, you know?
    All I can add to this thread is...
    oh, and...
    https://www.npr.org/2013/12/28/257559232/clippy-and-paula
    msg Posts: 10,650
    edited October 2022
    I just started playing around with this a couple of weeks ago. I set it up in a VM. You can still install it with a few registry adjustments to bypass the hardware check if your computer doesn't have TPM 2.0.
    I'm actually really enjoying it so far. To me, it seems like they've combined Win 10 framework with some style elements. That was one of the things I really liked about Win7 and some Linux distributions - they look nice, and are pleasing to use. Win11 is smooth, clean, looks really nice.
    Definitely have to customize it a bit to make it your own, but I like it better than Win10, almost as much as Win7, and never liked Win8. That was like a style prison.
    You can use your Win7 - 10 product key with it, too.
    https://www.microsoft.com/software-download/windows11
    This link has options to let you install/upgrade, create USB boot media, or download the .iso
    Techy tinkerers can download Oracle VirtualBox free to play around with desktop virtualization if you don't already use VMware, Fusion, or Hyper-V. Virtualization'll work best if you have at minimum 16GB RAM and a solid state disk.
    VR3 Posts: 29,763
    I have been using it for a few months.... Similar to windows 10. I disabled the center oriented task bar... Had been stable overall
    Mrs. H has a lappie with Win11.
    It's OK. I do not like the move away from words in the drop-down menus.
    I also don't like the fact that MS moved some of the stuff I use in the File Explorer (or whatever it might be called) into secondary menus.
    ... and let's just not even talk about the preschool-style interfaces that the Office 365 suite of apps have evolved over the last couple of years.
  • Emlyn
    Emlyn Posts: 4,920
    I updated my desktop a couple weeks ago. Went smoothly and didn’t take long. It does have the usual Microsoft annoyances of moving stuff around with menus and layout for no apparent reason. I wouldn’t say it’s an upgrade for me but doesn’t seem to have harmed anything. I did have to update a graphics driver after the update to Windows 11.
    msg Posts: 10,650
    I agree on anything preschool-styled. Like pretty much every website on the planet now. I don't need it to be in fat-crayon 36pt size to be able to read it.
    re: that secondary menu - the "simplified" context menu where you have to go more options to see the full context menu? you can also disable that with a reg key adjustment. still getting used to some stuff, and trying to be open about some changes and not immediately keep trying to recreate a Win7 experience.
    I do prefer the "compact view" in File Explorer. (funny to me, over the years, every time I used to ask a user to open Windows Explorer, they'd open Internet Explorer. Oh, sorry, I mean the yellow one. File Explorer is more concise at least, but yeah
    edited October 2022
    I like it but I'm not nears as smart some of you technically advanced lunatics,
    ( looking at you Scott ! You bright bastage😉) I had to use that red headed step child Win8 for a few years. That was as terrible as ME if not worse! When they updated my mothers pc to Win10 I was happy until I came home from work to find my mother had called someone to revert it back to Win 8, I walked out to the geerage and gave myself seven hard wacks upon my cranium.....
  • sucks2beme
    Win 11 orphans a whole lot of pc's.
    Anything more than a couple years old
    won't upgrade.
  • tonyp063
    tonyp063 Posts: 1,157
    edited October 2022
    Win11 is....adequate. I agree about the annoyance wrt things being removed. And yes, the O365 interface bites the big one.
    Thankfully I don't have to use it much.
    RedHat is how I earn my kibble.
  • Nightfall
    Nightfall Posts: 10,083
    edited October 2022
    Windows? Is that the thing that's always running behind my Steam and Xbox apps?
    I haven't had any qualms with Windows 11 yet. The auto HDR function is pretty nice.
    afterburnt wrote: »
    Village Idiot of Club Polk
    msg Posts: 10,650
    Well that doesn't sound like very much fun at all!
    Love my MBPs. Both platforms have their strengths and fit imho. I can't say one is better than the other overall.
  • CGTIII
    CGTIII Posts: 1,279
    edited November 2022
    Since Win10 just became generally stable on most machines last year, I expect Win11 could be generally stable next year. Still warning clients away from it for now. Also controlling updates for clients on Win10 and Win11 to avoid the bad updates. It's called Black Tuesday for many reasons.
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
    "Black Tuesday"... yeah, I get that. :#
    msg Posts: 10,650
    CGTIII wrote: »
    Curious, what kind of stability issues are you seeing or hearing? And what hardware?
  • sucks2beme
    I use a tablet 95% of the time. Don't care about windows that much.
  • CGTIII
    CGTIII Posts: 1,279
  • Milito
    Milito Posts: 2,008
    CGTIII wrote: »
    Just became generally stable on most machines last year?
    I haven't tried Windows 11, but Windows 10 Pro has been very stable for me for a long time.
