DIY Cable project
Whadyasay
Whadyasay Posts: 300
Hey All,
I decided to build some speaker cables to bi-wire my LSi9s and LSiC. I was using some 4-conductor 12GA Carol power/stage cable, which worked pretty well, but wanted to start from scratch with some better wire. Figured it would be fun.
I started out with Liberty Cable UltraCap THX in-wall...4-cond. 12GA/ea. The wires have a high strand count (much higher than the Carol) and the conductors are twisted more tightly and at a higer rate. Bought about 30 feet. Used TechFlex 3/8" covering in Carbon color, to give the overall cable a sort of metallic braid look.
In terms of sound, the bass was about the same as the older cables, but the highs are definitely cleaner and more extended, noticed particularly on the Norah Jones SACD, as well as a lot of jazz horns on both SACD and CD...probably nothing to do with the construction but rather the wire itself. Overall, a fun project that didn't take very long, and cost a total of about $80.00 in materials/wire.
Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
Post edited by Whadyasay on
  • Whadyasay
    edited March 2005
    Here are closeups of the two ends:
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2005
    Nice work ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • pjdami
    pjdami Posts: 1,894
    edited March 2005
    Agreed. Very nice work and a professional touch on top of that.
    DIY can be very rewarding and practical.
    Paul
  • HBombToo
    HBombToo Posts: 5,256
    edited March 2005
    Very Cool and I would not worry too much about strand interaction:D
    1/4twin
    ***WAREMTAE***
  • beardog03
    beardog03 Posts: 5,550
    edited March 2005
    what type of ends did you use ?
    are they twist , crimp ,or solder type?
    I was looking at some type 2 AQ wire in bulk..
    is this stuff any good ?
    any thoughts on any AQ bulk wire ?
    AA always has some kind of deal going, and with all the DYI`ers around here , I thought it looked like fun to try....
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2005
    Cool.
  • Whadyasay
    edited March 2005
    The amp end banannas are M*n$t#r twist-on's that I've had for years. The speaker ends are twist/crimp types that I bought in a package of 28 from some guy on ebay. I haven't tried AQ wire.
  • beardog03
    edited March 2005
    thanks ...
    I have only used twist ons...
    wasn`t sure about crimp type as I `m not sure how good of a connection it will make....
    I was going to try silver solder on my next speaker testing pair
    that I make...
    still looking for some decent bulk wire to try...
    probably use them in the garage or office rig
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
