How to Identify my model of Speakers
bigcarpileup
My brother gave me his Polk Audio Speakers that he bought new as well a Pioneer Receiver. I am trying to wire the whole thing up and make it sound as good as possible. I have moved twice since acquiring them and lost the metal jumpers for the terminals in the back. I don't know how many jumpers there originally were, but I now only have 1. Without the jumpers I decided to wire them up not knowing the first thing about "bi-wiring" and that has led me here.
My Main question is: How do I identify the model of Polk Audio Speaker that they are? I have looked all over the black exterior and have taken the black covers off the front that simply say "Polk Audio". They each have 2 mid-range looking speakers and 1 tweeter on the top. My last resort was to maybe unscrew them and look inside. Any other advice?
The model # i thought would help me to obtain the Jumpers online somewhere. Or I thought I could learn more about bi-wiring. So far my success with the bi-wiring is minimal. I have gotten some good sound, but if I go too far up with the volume, the receiver displays "OVERLOAD" and shuts down. At first I had the highs wired to the Front B connectors in the back, but after reading some about bi-wiring I put both the highs and lows in the Front A connectors.
Post edited by bigcarpileup on
take the grill off one of the speakers, set them side by side and take a picture then post it here. Someone will be able to identify it. Not enough in your description to do it for us.
For the jumper you lost, just cut a short length of speaker wire and use it like a jumper to connect the top and bottom red or black terminal together.
Before you change anything though - post the pictures to ensure that we are giving you the correct advice.
Michael
BTW - Welcome the Club Polk.Mains.............Polk LSi15 (Cherry)
Me thinks they are RT12, or RT16. But I agree, take a picture and you will have your answer in about 3 seconds. lolTV- Insignia 46'' LED,1080p,120hz
Monster Power center hts3600 mk2
Onkyo tx sr 503
Rm6600 with 4 sanus stands
SUB(DIY)
Dayton HPSA500, JVC Arsenal dvc 2ohm 12" wired to 4ohms in 1.5 cu ft sealed box
extras... RT10's.rti4s.atrium 5's.
"sticking feathers up your butt does not make you a chicken"-Tyler Durden -
Here are the photos of the speakers (atleast one of them). This one has a tweeter that is pushed in! don't know if that can be fixed.
As far as the "overload" problem, the only time this happens is when the tweeters are connected. If I disconnect them, I can turn the volume to max with no problems...
http://www.polkaudio.com/homeaudio/specs/recent/rt3000p/
It looks like the sub part is missing. You can try to pull the tweeter dome out with some tape.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Those are the Rt55 original, not the i series. You can make jumpers out of speaker wire to replace the lost ones. Some say that actually works better than the original. Oh, and try a vacuum to pull out the crushed tweeter."They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
messiah, November 23rd, 2010 -
Do you mean that slot on the bottom? Is that the subwoofer? -
No he was thinking they were something else. There is no sub part with that speaker, you have 2 mids and a tweeter.
http://www.polkaudio.com/homeaudio/products/recent/rt55i/ -this might help. The rt55 and the rt55i were almost the same. Some small changes were made but still pretty close. Didn't know I could post a link or I would have the first time.
As you may have already figured out, biamping requires 2 seperate amps. You do not want to wire the highs to the speaker A output and the lows to speaker B on your amp. Use the jumpers to connect the high and low terminals on the speakers to each other and then connect your speaker A output from your amp or receiver to the low terminals on the speakers.
Bi-wiring is just running 2 sets of wires to the same terminal on the speakers from the same speaker output on the amp. The only reason to remove the jumpers would be to bi-amp, that is to connect one amp to drive the highs and another to drive the lows.Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
I’m trying to also figure out what model speaker I have they have red on the front grill they are heavy and the serial number on the back is ls17 rc 01116
That sticker says LSi7 so guess what they are LSi7's
https://www.stereophile.com/standloudspeakers/795/index.html2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I'm a new owner of a set of Polk Audio speakers and a little confused about proper connections. No model number and all it says is see manual. Can anyone here please identify the model of "Powered Tower" speakers I have?
RT2000P
President of Club Polk -
Same RT2000P speakers.Political Correctness'.........defined
Can you identify these? Behind the top screen is a single midrange driver and tweeter, behind the bottom screen is wood. They are passive speakers.
RT1000 ?
Says Polk Audio right there in front.
The top receiver smells like a Sony.Political Correctness'.........defined
RT series. Looks like RT600i as they're passive. RT1000i were powered towers.
Mine was a hard guess of little more than knew they were RT.
I’m new here also and have the same question. These guys came from the thrift store today. I paid every penny of ten united state’s dollars for the pair…
Thanks in advance 🙏🏻 -
Oops
Monitor 5jr+ series 2
You paid nine United State’s dollars too much.Political Correctness'.........defined
Thanks muchly for the quickness of responsiveness.Monitor 5jr+ series 2
Dang, highway robberyYou paid nine United State’s dollars too much.
Given the size difference between the mid-woofer and the passive I think they might be Monitor 5 Series 2. The 5jr+ passive is the same size as the driver.
