Got some new toys today
13»
  • stangman67
    stangman67 Posts: 2,328
    tratliff wrote: »
    Now that you have found the problem go enjoy some good records.
    Another reason why dedicated circuits are needed.
    With that room being upstairs next to the attic do you have the ability to run a dedicated circuit?
    Do I have the ability, probably? I haven’t really looked at it, sure it wouldn’t be cheap. The panel is in the basement and I don’t remember if there are any spares. I’ll have to take a look at it and get it priced out
  • jdjohn
    jdjohn Posts: 3,384
    Glad you're sorted and can now enjoy the music! That RCA barrel thing makes me wonder if a wire connecting the ground lug to one of the RCA barrels would do anything.
  • stangman67
    jdjohn wrote: »
    Yea certainly is a good idea. I’ll keep that one tucked away in case something else happens in the future
    SCompRacer Posts: 9,127
    edited September 2022
    I was just going to pass on this fix posted at Hoffman forum. The claim is the RCA's are insulated from the RCA block. One of our forum members appears on page 2.
    https://forums.stevehoffman.tv/threads/how-i-finally-killed-my-hum-buzz-rfi-vpi-prime-scout.800981/
  • stangman67
    Very interesting, and good search skills! That reminds me of some car audio hacks I used back in the day. Figure 8 bare wire around the rca jacks always solved the ground loop hum. I was hesitant to do that with this setup because when I was using the temp ground wire I accidentally hit the rca and had a huge thump that caused my amp to go into protect. I’d be very wary of doing this on purpose. Although why the thump happened is beyond me with the signal level on a phono wire
  • stangman67
    I’m also trying to figure out how the hell that guy puts the records on his turntable with the lack of clearance he has there
    txcoastal1 Posts: 13,519
  • stangman67
    LOL. End of the year is my goal. I have tons of half finished projects laying around. I do listen to them a lot as they sit though.
  • stangman67 wrote: »
    Just a guess, but that may have been a static discharge.
