Got some new toys today
stangman67
stangman67 Posts: 2,328
edited September 2022 in 2 Channel Audio
This is a big one and checks off one of my sources in the “done” list.
Got a VPI prime signature with the JMW 10 Unipivot and ADS. Only problem is I have no idea where to put the ADS. Might have to add a 5th shelf to my rack. These are all very very much first world problems considering I was gifted this whole setup, I am most certainly a very lucky man.
Picked up a Soundsmith Zephyr MIMC cartridge and Nordost Blue Heaven phono cable to round out the package. Need to figure out the rack situation and hope to have the turntable assembled in some fashion this Sunday
«13
  • stangman67
  • tratliff
    tratliff Posts: 1,809
    You are going to love it. I have had a Prime for about 4 years. And it also has a Soundsmith Zephyr MIMC. Its a great setup. Which Phono pre will you be using?
    Congrats!
  • tratliff
    Also, that Uni-pivot can be tricky to setup. Give me a shout if you have any troubles. VPI has a good setup video on YouTube.
    treitz3 Posts: 20,076
    Very nice, Zach! You are about to have some serious fun.
  • stangman67
    tratliff wrote: »
    Congrats!
    I have a Modwright PH9.0x which just meets the minimum 470ohms of loading. I think it will be a great setup. Everything in the vinyl path is now what I consider end game stuff (I’ve said that before though lol)
  • stangman67
    tratliff wrote: »
    Thanks, I will watch some serious YouTube videos, I picked up the VPI dual pivot and Soundsmith counter intuitive to help me out as well. I will certainly reach out if I feel lost
    msg Posts: 10,458
    Phil Collins vinyl is about to dominate Ghent.
    msg Posts: 10,458
    I like when you change your mind about endgame stuff, Zach, 'cause then we get your sloppy seconds. I ain't proud.
    VR3 Posts: 29,526
    Beautiful!
    msg Posts: 10,458
    Wowwww, Zach, truly... that is end game. I BowDownToYou.
    msg Posts: 10,458
    Didn't you pick up a Wayne's Audio piece, too? If you don't have a ring clamp yet, that's your final accessory. Or pair, if do don't have his large center weight/clamp and edge. Totally worth it. I have done recordings for sonic waveforms, but it's raised my vinyl enjoyment 10x even with my SL1200mk5. So fun, so clean. No warps, just tight.
  • stangman67
    msg wrote: »
    I do indeed have a Wayne’s ring clamp that I will use with this VPI. The donator of this equipment didn’t want to give up his periphery clamp as he is gonna use it with his new VPI Avenger Direct Drive table.
    Clipdat Posts: 13,100
    Isn't this @Joey_V's old setup?
  • stangman67
    Haha no not at all. This was my fathers setup
    Oh ok, got it. I think he went with a very similar setup from VPI if I am remembering correctly.
    msg Posts: 10,458
    msg wrote: »
    That was supposed to be *haven't
  • stangman67
    Scott- I’ll have to have you over at some point for some feedback. At this point I haven’t had anyone else really knowledgeable other than my dad listen to my stuff and would love to hear some feedback from someone with good ears.
    My setup due to the room it is in will never be perfect but I think I have it dialed in fairly decently
    xschop Posts: 5,339
    stangman67 wrote: »
    Damn straight it is!
    Got it mocked up to verify it will even fit on my table. It’s so gorgeous, I can’t look away
    Looks like some contraption I'd build.
    If I had a vinyl collection, I'd want one of these Tables for looks alone.
    Very nice indeed.
  • Milito
    Milito Posts: 2,003
    Great looking setup, congrats!
  • stangman67
    Cartridge is on, but not aligned. Installed the dual pivot and Soundsmith counter intuitive as well 0dpxv2kgw6mv.jpeg
  • stangman67
    Got up early to finish the setup. Up and playing now, have some hum now with the phono turned on so will have to try to sort that later.
    First couple songs sound good, nothing glaringly wrong at the outset. This is my first time setting up a cart so I am expecting a few growing pains
  • SIHAB
    SIHAB Posts: 5,553
    Awesome kit!
    Would you care to offer your initial thoughts on sound with the VPI/SS cart versus the Rega/Ania? I have been eying this table/cart combo for a while and would be moving along from a MH MMF-5 w/ a Goldring cart.
    Might want to experiment with a wire from the TT chassis/ground to the screw that holds the wall plate on at the outlet or the phono pre. Or maybe a ground wire from the Phono pre to your pre. Should (in theory) be pretty simple, just need to experiment a bit. Once you find it, find a way to permanently mount said wire.
    msg Posts: 10,458
    stangman67 wrote: »
    Hey Zach - making great progress there!
    Yeah, that'd be great. I'll pick out a couple of records good for stereo presentation to try out (clean, of course!) Might need to fly in @jdjohn for a consultation :D
    re: cart alignment, I ordrered one of these alignment protractors to try out. Haven't used it yet, but I remember when I was looking, I happened across Legendary Audio and these discs. Pretty nice kit of the disc and detailed instructions. Apparently customized for various turntables.
    Here's the link to the Ebay store with all protractors listed. You can refine your search for a particular table, e.g., Technics, etc.
    Here are the VPI protractors. The JMW-10 is listed.
    SCompRacer Posts: 9,121
    I second awesome kit! I start touching things while grounding myself to see if hum changes/goes away. Scary stuff if you have a short...lol, so use wire like Tom suggested.
    Years ago, after my last TT upgrade, I was selling my Nottingham Space 294 with Moerch DP-6 arm. I took it to an interested party who wanted to buy the table more for looks than function. He had a Music Hall, maybe entry level or a little better with I forget which cartridge, maybe a 2M Blue. I said let's put your cartridge on the 294 and listen to my table with your system before you commit.
    We were amazed at the difference in presentation. Quieter background, deeper bass, improved mids and highs. The table alone was a big upgrade. Reinstalled the Karat 17D3 and it sounded even better. It is time consuming doing cartridge swaps, but it provides setup experience, and it is the best way to hear what a new table brings before you install the better cartridge.
  • stangman67
    It’s hard for me to go into detail comparing the P6 and the VPI. I haven’t spun a record on the P6 in many many months so it’s hard to really give you specific feedback. The VPI is certainly the better player, as it should be for 3-4 times the cost. The vpi is quieter for sure( except for the hum), that is one thing I can say for sure.
  • stangman67
    As far as the hum goes, it’s a transformers sound, and is variable with volume. When i touch the grounding terminal on the turntable it disappears. I have a ground wire present from the turntable to phono pre. I tried to run another from the tt to wall plate and preamp as suggested to no avail. Since the hum disappears when I touch the turntable ground lug, I’d have to imagine I need to ground it to something. I just don’t know where.
    I also tried to plug the turntable directly into the wall vice the power conditioner, same symptoms. Any other suggestions on how to chase this?
  • If the hum persists, make sure the the TT Interconnects are not lying over a power cord. Also try and separate the the power supply from the Phono Preamp.
    Low and slow or angry wasp hum?
