Rg11
VR3
Before I had a rg6, copper plated steel, 60 ft going to my modem/router in the back of the house then wirelessly connected to the living room.
Decided to run a 60 ft rg11, 14 awg solid copper, directly to the modem from outside to the living room...
So now it is a hard connection from the box to the lumin.
Will update on the result!
Ordered the rg11 from Belden, had it in two days!
Post edited by VR3 on
Isn't that cable RG11 coax?
Yes- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I take it there's a step down to the lumin? I don't see you stuffing that monster 14g conductor directly into the coax port.
Now my post looks stupid
the RG11 plugs directly into the back of the modem.
Modem > router > lumin - no couplers or anything in between- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Interesting I would have thought the wire would be too large.
Here's a cut away of some Chinese cables
So, initial listening tests, I do not hear any perceived difference between direct hard wire and the prior setup- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Do you use a CAT cable from the modem to the Lumin, or still wireless there?"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Everything is hard wired in the new setup versus half hardwired, half wireless last time.
The lumin has no wireless capabilities
Old setup
Hardwired to modem, Rg6 copper plated steel
Ethernet to main mesh router hub
Secondary Wireless mesh hub, about 50 ft, ethernet to lumin- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Gotcha. Have you ever tried an ethernet filter device for audio? I took a punt on an Network Acoustics eno ethernet filter, hand-made by a dude in the UK. https://www.networkacoustics.com/eno/ It's a passive device. He also recommends adding a switch (nothing expensive) just before the streamer as well.
I can't say it is a night-and-day difference...it's actually a little quieter, and requires more gain/volume...so I'm not really sure what to make of it. They tout that it makes the biggest difference with true high-res sources (like Qobuz, Tidal, or high-res NAS files). I use Spotify, and my FLAC/DSD files are stored directly on my Innuos Zen, so not sure I'm getting the expected benefit."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I looked into those back when you posted about them and thought the price was just to much plus adding more components in the chain- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
PM me if you'd like to give it a trial run. We might even get a 'tour' going if there was enough interest."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
So do you currently run this 24/7?
Interesting build
Yep, I reckon that's it. But again, in my case, it only comes into play when streaming via Spotify. My local files are stored on my Innuos Zen's internal drive, so the ethernet cable is not involved."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Makes sense! Have you compared Spotify to tidal, quobuz, etc- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I have not, but should probably give Qobuz a try since Spotify will not ****, or get off the pot on hi-res. Qobuz works natively with the Innuos streamers, so that's another plus. The thing is: I have most of my favorites ripped to FLAC from CD, or purchased/downloaded at a higher bit-rate from HD Tracks for local storage, so don't really need Qobuz. Plus, I've put some effort into developing my library on Spotify for things I don't actually own, and it's all portable via smartphone, SqueezeBox Touch, etc."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I seriously cannot believe it's been this long since their announcement. Mind boggling. What is taking them so long?
"In February 2021, Spotify announced their plans to introduce a HiFi subscription, to offer listening in high fidelity, lossless sound quality. The rollout for the HiFi tier is yet to be announced." -
I have no doubts if you email them about it they will tell you Covid is the blame.
defacto excuse for any delay the last 2 years or so- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
