Rg11
VR3
VR3 Posts: 29,733
edited September 2022 in 2 Channel Audio
Before I had a rg6, copper plated steel, 60 ft going to my modem/router in the back of the house then wirelessly connected to the living room.
Decided to run a 60 ft rg11, 14 awg solid copper, directly to the modem from outside to the living room...
So now it is a hard connection from the box to the lumin.
Will update on the result!
Ordered the rg11 from Belden, had it in two days!
  • invalid
    invalid Posts: 1,559
    Isn't that cable RG11 coax?
    VR3 Posts: 29,733
    Yes
    pitdogg2 Posts: 27,895
    I take it there's a step down to the lumin? I don't see you stuffing that monster 14g conductor directly into the coax port.
  • invalid
    Now my post looks stupid
    VR3 Posts: 29,733
    the RG11 plugs directly into the back of the modem.
    Modem > router > lumin - no couplers or anything in between
    Interesting I would have thought the wire would be too large.
    VR3 Posts: 29,733
    Here's a cut away of some Chinese cables
    VR3 Posts: 29,733
    So, initial listening tests, I do not hear any perceived difference between direct hard wire and the prior setup
  • jdjohn
    jdjohn Posts: 3,441
    Do you use a CAT cable from the modem to the Lumin, or still wireless there?
    VR3 Posts: 29,733
    Everything is hard wired in the new setup versus half hardwired, half wireless last time.
    The lumin has no wireless capabilities
    Old setup
    Hardwired to modem, Rg6 copper plated steel
    Ethernet to main mesh router hub
    Secondary Wireless mesh hub, about 50 ft, ethernet to lumin
  • jdjohn
    jdjohn Posts: 3,441
    Gotcha. Have you ever tried an ethernet filter device for audio? I took a punt on an Network Acoustics eno ethernet filter, hand-made by a dude in the UK. https://www.networkacoustics.com/eno/ It's a passive device. He also recommends adding a switch (nothing expensive) just before the streamer as well.
    I can't say it is a night-and-day difference...it's actually a little quieter, and requires more gain/volume...so I'm not really sure what to make of it. They tout that it makes the biggest difference with true high-res sources (like Qobuz, Tidal, or high-res NAS files). I use Spotify, and my FLAC/DSD files are stored directly on my Innuos Zen, so not sure I'm getting the expected benefit.
    VR3 Posts: 29,733
    I looked into those back when you posted about them and thought the price was just to much plus adding more components in the chain
  • jdjohn
    jdjohn Posts: 3,441
    PM me if you'd like to give it a trial run. We might even get a 'tour' going if there was enough interest.
    VR3 Posts: 29,733
    So do you currently run this 24/7?
  • jdjohn
    jdjohn Posts: 3,441
    Yep, I reckon that's it. But again, in my case, it only comes into play when streaming via Spotify. My local files are stored on my Innuos Zen's internal drive, so the ethernet cable is not involved.
    VR3 Posts: 29,733
    Makes sense! Have you compared Spotify to tidal, quobuz, etc
  • jdjohn
    jdjohn Posts: 3,441
    I have not, but should probably give Qobuz a try since Spotify will not ****, or get off the pot on hi-res. Qobuz works natively with the Innuos streamers, so that's another plus. The thing is: I have most of my favorites ripped to FLAC from CD, or purchased/downloaded at a higher bit-rate from HD Tracks for local storage, so don't really need Qobuz. Plus, I've put some effort into developing my library on Spotify for things I don't actually own, and it's all portable via smartphone, SqueezeBox Touch, etc.
    Clipdat Posts: 13,104
    I seriously cannot believe it's been this long since their announcement. Mind boggling. What is taking them so long?
    "In February 2021, Spotify announced their plans to introduce a HiFi subscription, to offer listening in high fidelity, lossless sound quality. The rollout for the HiFi tier is yet to be announced."
    VR3 Posts: 29,733
    I have no doubts if you email them about it they will tell you Covid is the blame.
    defacto excuse for any delay the last 2 years or so
