SDA II price in line?
ramm440
Found these locally any thoughts if they are worth it? Thanks
Check out this item on OfferUp. https://offerup.co/76sMrIPeKmb
They should be priced between 150 and 200 dollars to get my attention.
I'm sorry they wouldn't ever get my attention with the exception that I'd remove the drivers for my SDA1 Signatures.
350 is far too high -
Unfortunately these are at the bottom of the food chain in SDA’s, along with the original CRS’s, not highly sought after like other models, I agree on the $150-$200 range..
They would have a better chance at $350 parting them out.. -
So what are a wanted SDA or other to keep my eye out for?
Later 4th and 5th generation of the series.
Most any that are pin/blade interconnect. -
How do these look?
NiceSDA SRS 2.3TL's
SDA 2B TL's -
Can I get feed back on if these are on the most wanted list? For sda 2bs
Yes.Those are on the list.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Those desirable 2B's look in pretty good shape. The color of the end caps is not original though.Political Correctness'.........defined
President of Club Polk -
Those are keepers! Do all the mods and they'll be hard to beat.
F1 kinda looks like walnut stain on original oak maybe?
Yep, some dark brown stain or even black paint wiped back leaving most of the paint in the grain. Looks like crap, IMO.Political Correctness'.........defined
I think that's walnut but someone put something on it that enhanced the grain way too much. Probably could be made better with some effort.Gustard X26 Pro DAC
That is oak, not walnut.
I'm at least 50% sure it's Walnut.Gustard X26 Pro DAC
I'm 100% positive it is oak.Political Correctness'.........defined
Ever pound a nail into oak. Be ready for a workout
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Could be old english dark… that gunk will be hard to lighten without making it worse
So its hard to split black oak?
Not a problem with the old MC paint stripper.Political Correctness'.........defined
boston1450 wrote: »Ever pound a nail into oak. Be ready for a workout
Usually they bendSo its hard to split black oak?
Whoa, wait! No one said to take an axe to your oak end caps!Gustard X26 Pro DAC
So the seller has upped his price to 400.00 delivered to my door. It was 350.00 and I have only seen pics that I posted nothing like hands on. Oh yeah no interconnect cable either.
Thoughts? -
I am about to respond to him about how the magnets slide and need jb welded, new tweeters and dynamat
That's where the fun begins. 2b's are a great speaker & very affordable to upgrade. Good luckRandy-Maine
by David WMG
Just found these locally has interconnect cable blade-pin.
Seller Posted as sda 2 but don’t they look like sda 2b studio? Any help appreciated.
Pin/blade equates to SDA 2b.
Thanks but now the owner said sorry his mistake they are blade- blade interconnect cable. Would they most likely be sda 2a or is the only true way to tell is to open them up verify 2a or 2b by seeing what numbers are printed on the driver magnets?Post edited by ramm440 on
Thanks but now the owner said sorry his mistake they are blade- blade interconnect cable. Would they most likely be sda 2a then or is the only true way to tell is to open them up verify 2a or 2b by seeing what numbers are printed on the driver magnets?
They could still be 2B's. I bought a set of black studios very cheap and I assumed they were 2A because they were blade/blade. I was pleasantly surprised when I opened them and discovered the correct 2B drivers and single crossover board (2A has dual board crossover).
