Polk Monitor T8 question
Hello, can anyone tell me the difference between a Polk Monitor T8 and a Polk Monitor T8 that has been THX certified? Are the drivers the same? Would they both sound the same for simple two channel stereo listening? Customer service had no idea.
Thank you
    F1nut Posts: 51,781
    Yep, Polk paid a licensing fee to use the THX description. Other than that...zip.
  • skrol
    skrol Posts: 3,452
    Polk Monitor T8? Not familiar with that one.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • On the back of the speaker it simply has 8T and a serial number
  • On the wiring connector plate it says Lucas Film Audio THX
    Clipdat Posts: 13,095
    I didn't think Polk ever made any THX certified speakers.
  • skrol
    skrol Posts: 3,452
    Pictures?
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • This was bothering me so much that I contacted the previous owner (who has since moved) (And might be taking a restraining order out against me) and they stated that they placed a transparent sticker from some other set of speakers on there because they used them as rear speakers in a surround sound system and that they are RTA 8T s. Thank you for your help .I'm sorry to bother everyone.
    F1nut Posts: 51,781
    No bother, glad you found out the proper model.
    As I previously stated, the THX label on any piece of gear requires a paid licensing fee. Any piece of gear carrying the label is supposed to meet certain specs, but don't hold your breath on that one.
  • skrol
    skrol Posts: 3,452
    Aaaaa, the RTA-8T makes more sense. I think some early ones were labeled Monitor 8T. I was wondering if I missed something with the T8 and THX labeling.
    Stan
    Main 2ch:
    HT:
    Other stuff:
