RTiA 6.5" driver Phase Plugs
xschop
I have 6 available for the RTi-A drivers if anyone is interested, just PM.
$55 /pair shipped US-48 ONLY
Typo. Should be $45 per pair shipped US-48 ONLY.Don't take experimental gene therapies from known eugenicists.
For anyone who cares in addition to xschop (thanks again, Rob) here’s a “foamed*” & “plugged” RTi A7 mid…
…carefully hand tighten each screw 2-3 turns like a cylinder head…
…mounted in its home w/painted trim ring and Trey’s diffraction pad.
*per Garden Stater’s Foam threadSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
I tested the upgrade listening to Dave Grusin's "Discovered Again" on Sheffield. SQ improvement well worth the effort!
I heard sounds and music details I did never heard before! "Plugging" in addition to "foaming" the frames are both worthwhile. For any music lover using RTi or RTi A series speakers, get in touch w/ the man - Xschop!
Bump for more RtiA plug mods on the horizon.Don't take experimental gene therapies from known eugenicists.
If you have crappy midrange, the loose (and brittle) dustcaps are the culprit. I pulled them off by fingernails too easily and the edges where crumbly. One was dry-rotted and partially detached from glue....
Post edited by xschop onDon't take experimental gene therapies from known eugenicists. -
1 single drop wintergreen oil to capful olive oil is the sweet spot for fixing these dried out surrounds...
What does wintergreen oil bring to the party?
From which container did you use the cap to measure? Maybe a tsp? EVOO😂?1 single drop wintergreen oil to capful olive oil is the sweet spot for fixing these dried out surrounds...
Related note: Sunfire recommends for their “True” sub signature models, once annually rub some mink oil on both the driver & passive radiator surrounds.Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
These will be back on their way to GA Monday.Don't take experimental gene therapies from known eugenicists.
No rush.
I much prefer “Quality over quickly.”
Sorry for forgetting to tell you: do NOT sweat the existing Armacell. Upon return I need to “foam” them before returning them to their closure.
1K thanks. Please PM return $hipping.
TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
It brings a minty-fresh breath of suppleness. I tested a few solutions/concentrations and the isopropyl alchol dries up too quickly.
Looking forward to the center channel pics.Don't take experimental gene therapies from known eugenicists. -
1K thanks Rob for your knowledge & expertise.
Update for the drivers* pictured in the Aug 17th post: completed driver side Foaming, Sep 8th afternoon. A couple of the “Joys” of home owership has sidelined returning the same* to their Center speaker closure😢.
Pics to follow on my CSi A6 mod thread.
https://forum.polkaudio.com/discussion/175612/tri-amped-csi-a6#latest
No tweak last Saturday. My RTA (Behringer DEQ-2496) went belly up since the last time I used it😢Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
RTiA 5.25" midranges in process...
These will also need 0.180" shorter base phase plugs. The 50% Alcohol with Wintergreen is perfect for soaking dust cap perimeters and restoring the butyl surrounds on these without worrying about damaging them....
