How to Identify my model of Speakers
bigcarpileup
bigcarpileup Posts: 7
edited October 2009 in Speakers
My brother gave me his Polk Audio Speakers that he bought new as well a Pioneer Receiver. I am trying to wire the whole thing up and make it sound as good as possible. I have moved twice since acquiring them and lost the metal jumpers for the terminals in the back. I don't know how many jumpers there originally were, but I now only have 1. Without the jumpers I decided to wire them up not knowing the first thing about "bi-wiring" and that has led me here.
My Main question is: How do I identify the model of Polk Audio Speaker that they are? I have looked all over the black exterior and have taken the black covers off the front that simply say "Polk Audio". They each have 2 mid-range looking speakers and 1 tweeter on the top. My last resort was to maybe unscrew them and look inside. Any other advice?
The model # i thought would help me to obtain the Jumpers online somewhere. Or I thought I could learn more about bi-wiring. So far my success with the bi-wiring is minimal. I have gotten some good sound, but if I go too far up with the volume, the receiver displays "OVERLOAD" and shuts down. At first I had the highs wired to the Front B connectors in the back, but after reading some about bi-wiring I put both the highs and lows in the Front A connectors.
Post edited by bigcarpileup on
  • McLoki
    McLoki Posts: 5,231
    edited October 2009
    take the grill off one of the speakers, set them side by side and take a picture then post it here. Someone will be able to identify it. Not enough in your description to do it for us.
    For the jumper you lost, just cut a short length of speaker wire and use it like a jumper to connect the top and bottom red or black terminal together.
    Before you change anything though - post the pictures to ensure that we are giving you the correct advice.
    Michael
    BTW - Welcome the Club Polk.
  • polkanddie
    polkanddie Posts: 224
    edited October 2009
    Me thinks they are RT12, or RT16. But I agree, take a picture and you will have your answer in about 3 seconds. lol
    TV- Insignia 46'' LED,1080p,120hz
    Monster Power center hts3600 mk2
    Onkyo tx sr 503
    Rm6600 with 4 sanus stands
    SUB(DIY)
    Dayton HPSA500, JVC Arsenal dvc 2ohm 12" wired to 4ohms in 1.5 cu ft sealed box
    extras... RT10's.rti4s.atrium 5's.
    "sticking feathers up your butt does not make you a chicken"-Tyler Durden
  • bigcarpileup
    edited October 2009
    Here are the photos of the speakers (atleast one of them). This one has a tweeter that is pushed in! don't know if that can be fixed.
    As far as the "overload" problem, the only time this happens is when the tweeters are connected. If I disconnect them, I can turn the volume to max with no problems...
  • ben62670
    ben62670 Posts: 15,969
    edited October 2009
    http://www.polkaudio.com/homeaudio/specs/recent/rt3000p/
    It looks like the sub part is missing. You can try to pull the tweeter dome out with some tape.
    Ben
  • messiah
    messiah Posts: 1,790
    edited October 2009
    Those are the Rt55 original, not the i series. You can make jumpers out of speaker wire to replace the lost ones. Some say that actually works better than the original. Oh, and try a vacuum to pull out the crushed tweeter.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • bigcarpileup
    edited October 2009
    Do you mean that slot on the bottom? Is that the subwoofer?
  • w_coyote
    w_coyote Posts: 66
    edited October 2009
    No he was thinking they were something else. There is no sub part with that speaker, you have 2 mids and a tweeter.
  • w_coyote
    w_coyote Posts: 66
    edited October 2009
    http://www.polkaudio.com/homeaudio/products/recent/rt55i/ -this might help. The rt55 and the rt55i were almost the same. Some small changes were made but still pretty close. Didn't know I could post a link or I would have the first time.
  • classic carl
    classic carl Posts: 661
    edited October 2009
    As you may have already figured out, biamping requires 2 seperate amps. You do not want to wire the highs to the speaker A output and the lows to speaker B on your amp. Use the jumpers to connect the high and low terminals on the speakers to each other and then connect your speaker A output from your amp or receiver to the low terminals on the speakers.
    Bi-wiring is just running 2 sets of wires to the same terminal on the speakers from the same speaker output on the amp. The only reason to remove the jumpers would be to bi-amp, that is to connect one amp to drive the highs and another to drive the lows.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk RT55i ~ Polk Audio RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI 200C ~ Dayton Audio SUB-1200
  • I’m trying to also figure out what model speaker I have they have red on the front grill they are heavy and the serial number on the back is ls17 rc 011161z75ua8vcrlz.jpeg
    txcoastal1 Posts: 13,499
    That sticker says LSi7 so guess what they are LSi7's
    https://www.stereophile.com/standloudspeakers/795/index.html
  • FirstSetOfPolk
    FirstSetOfPolk Posts: 2
    edited August 2022
    I'm a new owner of a set of Polk Audio speakers and a little confused about proper connections. No model number and all it says is see manual. Can anyone here please identify the model of "Powered Tower" speakers I have? n7s3j0celgzs.jpg
    F1nut Posts: 51,659
    RT2000P
    F1nut Posts: 51,659
    Same RT2000P speakers.
  • jlwshmily
    jlwshmily Posts: 1
    edited October 2022
    Can you identify these? Behind the top screen is a single midrange driver and tweeter, behind the bottom screen is wood. They are passive speakers. pqz1g8n18gh4.jpeg
    F1nut Posts: 51,659
    edited October 2022
    Says Polk Audio right there in front.
    The top receiver smells like a Sony.
  • Emlyn
    Emlyn Posts: 4,616
    RT series. Looks like RT600i as they're passive. RT1000i were powered towers.
    pitdogg2 Posts: 26,915
    Mine was a hard guess of little more than knew they were RT.
  • AuggieWest
    AuggieWest Posts: 4
    I’m new here also and have the same question. These guys came from the thrift store today. I paid every penny of ten united state’s dollars for the pair…
    Thanks in advance 🙏🏻
    edited April 24
    Monitor 5jr+ series 2
    F1nut Posts: 51,659
    You paid nine United State’s dollars too much.
  • AuggieWest
    AuggieWest Posts: 4
    Thanks muchly for the quickness of responsiveness.
    Dang, highway robbery
  • stevep
    stevep Posts: 357
    Given the size difference between the mid-woofer and the passive I think they might be Monitor 5 Series 2. The 5jr+ passive is the same size as the driver.
