Advice on Choosing New CD Player - Marantz 6007, Emotiva ERC-4, & Rotel CD 11 Tribute
Hi everyone, I'm looking for a cd player to replace my aging Sony CA7ES which I love. I'm on my second one and know it's just a matter of time until it starts skipping again. I'm about 2 or 3 months from making a purchase and the ones I'm looking at to replace it are the Marantz CD6007, Emotiva ERC-4, and the Rotel CD 11 Tribute. Sound quality is the number one factor to me, and listening to music is my main purpose. I'd prefer something that has a similar sound to my sony because to my ears it is absolutely fantastic with my setup. I'd also prefer something with a digital out because I have an external DAC as well. I'm running a 2 channel setup, I may move to 5.1 eventually but that's way down the road. If it helps, here's my current setup (please stick to cd player suggestions as I am not interested in changing any of my other gear at this point). Please tell me which player you recommend and why. Thanks in advance.
Preamp - Outlaw Model 990
Amp - NAD 2200PE (which will be upgraded/refurbished in a couple of weeks)
CD Player Sony CDP-CA7ES
DAC - SMSL SU-9N
Speakers - Polk LSi 15
Sub - Rythmik L12
Best Answer
Answers
  • tratliff
    tratliff Posts: 1,910
    edited August 2022
    You should take a look at the Marantz SA-14S1 I have for sale. It’s a great player. Hard to beat for the price.
    https://forum.polkaudio.com/discussion/196968/fs-marantz-sa-14s1-sacd-cd#latest
    Good luck with whatever you choose.
    2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Signature 21 w/Hana Umami Red, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
    gudnoyez Posts: 8,235
    Marantz 6007, I have several Marantz players and highly recommended them.
    If you could swing the price difference, the above SA-14S1 that's for sale is well worth it.
  • crazy098
    crazy098 Posts: 28
    tratliff wrote: »
    That is a great player. Unfortunately out of my price range though.
  • Milito
    Milito Posts: 2,008
    edited August 2022
    Audiolab 6000CDT CD Transport. Check the reviews. Also plays discs others won't.
  • muncybob
    muncybob Posts: 3,356
    A reviewer on Amazon likes the Audiolab over the mentioned Marantz. I have a Marantz and it def was an improvement over the Oppo 93 I had.
    Yep, my name really is Bob.
    Rogue Audio Conus Magnum iii Dark, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub.
  • crazy098
    crazy098 Posts: 28
    Thanks for the Audiolab suggestion but I'm not interested in a transport at this time.
    F1nut Posts: 52,406
    Since you believe your Sony 5 disc spinner sounds fantastic (shutter...) I suggest you go with a similar example such as the Onkyo DX-C390.
  • crazy098
    crazy098 Posts: 28
    edited August 2022
    Specs on ca7es from the manual:
    Frequency response: 2 Hz-20 Khz
    Signal to Noise Ratio: More than 117 dB
    Dynamic Range: More than 99 dB
    Harmonic Distortion: Less than .0025%
    Channel Seperation: More than 110dB
    Thanks, but the Onkyo would be a downgrade.
    F1nut Posts: 52,406
    I'm very familiar with the Sony house sound, which specs do not show. The Onkyo would sound a lot closer to the Sony. Marantz sounds nothing like Sony.
  • jbreezy5
    jbreezy5 Posts: 1,141
    Milito wrote: »
    Flee the 6000CDT like the plague. It does scratch discs. I’ve written about this with photo evidence on this forum.
    Alternatively, Cambridge Audio CXC Transport is serving me well.
    I like the Marantz CD-6007 also, but don’t own one. Have only used it at Magnolia Best Buy.
  • Emlyn
    Emlyn Posts: 4,920
    Pretty difficult to beat a Marantz CD player for simple two channel music in their various price ranges from my experience. I like both Sony ES and Marantz but they are quite different.
    If I had a CA7ES, I liked its sound quality, and it still worked I wouldn't get another disc spinner. Especially with a separate DAC in the system. What's the issue with the CA7ES? Does the DAC perform better?
  • crazy098
    crazy098 Posts: 28
    edited August 2022
    Emlyn wrote: »
    The issue with them is that in my experience they are prone to failure. My first one started skipping randomly during playback. My 2nd one is developing issues. I can hear the discs becoming loose when switching from disc to disc. I won't have my dac for another week so I can't compare it. I have a large collection of cd's that I've acquired over the years and if I decide I don't like the dac or need to send it in for service at least I know I'll have something that will sound good in the meantime. Plus, I enjoy having the physical copy of the cd. I wish I could demo a Marantz, unfortunately there are none available by me.
  • Emlyn
    Emlyn Posts: 4,920
    Unfortunately disc transports all eventually fail with age and use. Disc changers seem to have more problems than single disc players. An option is to look for a used Sony ES level DVD player from a few years back. I was impressed with the quality of one I had. Might have been a 9100ES or something like that.
  • Milito
    Milito Posts: 2,008
    jbreezy5 wrote: »
    Milito wrote: »
    Mine hasn't scratched a disc yet. Guess I got a good one.
  • jbreezy5
    Milito wrote: »
    jbreezy5 wrote: »
    Milito wrote: »
    I’m happy for you.
  • skrol
    skrol Posts: 3,500
    Even the entry level Marantz CD players have a sweetness to the sound. I have a CD5004 that I really like but have it in storage since it doesn't do SACD or DVD-A. Actually, I could work a deal on it if interested. It is in really nice shape and I believe I have the remote.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 52,406
    The OP told me he made a decision, but he didn't say what that was.
  • crazy098
    crazy098 Posts: 28
    The Marantz. I picked up a nr1504 for $100 to get an idea of the sound and I love it.
