Advice on Choosing New CD Player - Marantz 6007, Emotiva ERC-4, & Rotel CD 11 Tribute
crazy098
Hi everyone, I'm looking for a cd player to replace my aging Sony CA7ES which I love. I'm on my second one and know it's just a matter of time until it starts skipping again. I'm about 2 or 3 months from making a purchase and the ones I'm looking at to replace it are the Marantz CD6007, Emotiva ERC-4, and the Rotel CD 11 Tribute. Sound quality is the number one factor to me, and listening to music is my main purpose. I'd prefer something that has a similar sound to my sony because to my ears it is absolutely fantastic with my setup. I'd also prefer something with a digital out because I have an external DAC as well. I'm running a 2 channel setup, I may move to 5.1 eventually but that's way down the road. If it helps, here's my current setup (please stick to cd player suggestions as I am not interested in changing any of my other gear at this point). Please tell me which player you recommend and why. Thanks in advance.
Preamp - Outlaw Model 990
Amp - NAD 2200PE (which will be upgraded/refurbished in a couple of weeks)
CD Player Sony CDP-CA7ES
DAC - SMSL SU-9N
Speakers - Polk LSi 15
Sub - Rythmik L12
Best Answer
Marantz CD6007 for sure.
Answers
You should take a look at the Marantz SA-14S1 I have for sale. It’s a great player. Hard to beat for the price.
https://forum.polkaudio.com/discussion/196968/fs-marantz-sa-14s1-sacd-cd#latest
Good luck with whatever you choose.2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables -
Marantz 6007, I have several Marantz players and highly recommended them.
If you could swing the price difference, the above SA-14S1 that's for sale is well worth it.Home Theater
That is a great player. Unfortunately out of my price range though. -
Audiolab 6000CDT CD Transport. Check the reviews. Also plays discs others won't.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
A reviewer on Amazon likes the Audiolab over the mentioned Marantz. I have a Marantz and it def was an improvement over the Oppo 93 I had.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Thanks for the Audiolab suggestion but I'm not interested in a transport at this time.
Since you believe your Sony 5 disc spinner sounds fantastic (shutter...) I suggest you go with a similar example such as the Onkyo DX-C390.
Specs on ca7es from the manual:
Frequency response: 2 Hz-20 Khz
Signal to Noise Ratio: More than 117 dB
Dynamic Range: More than 99 dB
Harmonic Distortion: Less than .0025%
Channel Seperation: More than 110dB
Thanks, but the Onkyo would be a downgrade. -
I'm very familiar with the Sony house sound, which specs do not show. The Onkyo would sound a lot closer to the Sony. Marantz sounds nothing like Sony.
Flee the 6000CDT like the plague. It does scratch discs. I’ve written about this with photo evidence on this forum.
Alternatively, Cambridge Audio CXC Transport is serving me well.
I like the Marantz CD-6007 also, but don’t own one. Have only used it at Magnolia Best Buy.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
Pretty difficult to beat a Marantz CD player for simple two channel music in their various price ranges from my experience. I like both Sony ES and Marantz but they are quite different.
If I had a CA7ES, I liked its sound quality, and it still worked I wouldn't get another disc spinner. Especially with a separate DAC in the system. What's the issue with the CA7ES? Does the DAC perform better? -
The issue with them is that in my experience they are prone to failure. My first one started skipping randomly during playback. My 2nd one is developing issues. I can hear the discs becoming loose when switching from disc to disc. I won't have my dac for another week so I can't compare it. I have a large collection of cd's that I've acquired over the years and if I decide I don't like the dac or need to send it in for service at least I know I'll have something that will sound good in the meantime. Plus, I enjoy having the physical copy of the cd. I wish I could demo a Marantz, unfortunately there are none available by me. -
Unfortunately disc transports all eventually fail with age and use. Disc changers seem to have more problems than single disc players. An option is to look for a used Sony ES level DVD player from a few years back. I was impressed with the quality of one I had. Might have been a 9100ES or something like that.
Mine hasn't scratched a disc yet. Guess I got a good one.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream -
I’m happy for you.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Even the entry level Marantz CD players have a sweetness to the sound. I have a CD5004 that I really like but have it in storage since it doesn't do SACD or DVD-A. Actually, I could work a deal on it if interested. It is in really nice shape and I believe I have the remote.Stan
Main 2ch:
HT:
Other stuff:
The OP told me he made a decision, but he didn't say what that was.
The Marantz. I picked up a nr1504 for $100 to get an idea of the sound and I love it.
