Mixing Home Audio With Mobile Audio
glemay
glemay Posts: 574
Hey guys,
Didn't really know where to post this but spring isn't to far away and the work on the boat will soon begin. But the point is as some of you know we put some home audio equipment in our boat, therefore my dad wants to take the rest of the mobile audio equipment out.
Now what I'm thinking is that the only decent piece of mobile audio equipment we have is a 400 Watt Clarion Amplifier. Seeing as we don't have a subwoofer for the boat I was think why not put that amplifier to good use and pick up a subwoofer and box and use the Clarion amplifier to run it so we round out the sound wit some nice low end.
My question is, would I be able to run a Y-Splitter from the sub pre-out on the Denon to the Clarion amplifier?
Thanks Guys
Gerald Lemay
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Post edited by glemay on
  • Mjr7531
    Mjr7531 Posts: 856
    edited February 2005
    If they are both the same level of signal, yes, I wouldn't see why you can't.
  • PolkThug
    PolkThug Posts: 7,532
    Yes, just adjust your gains accordingly on the Clarion amp.
  • glemay
    glemay Posts: 574
    Checked out the amp today and something just dawned on me. What will I do about the control wire on the amp? If we use the amp along with our Denon AVR-2805, we won't have a control wire to tell the amplifier to turn on.
    Is there a way around this?
    Gerald
    Main System:
    Second System:
  • glemay
    glemay Posts: 574
    Anyone got any ideas?
    Main System:
    Second System:
  • Toxis
    Toxis Posts: 5,116
    I'm not recommending this but I'm just going to throw this out as a possibility. A remote wire on a CA radio basically just sends a 12v signal to the amp to turn it on. Isn't this the exact same thing that the mini plug on the back of the denon would do for an external amp? And if I remember correctly, those outputs are typically just a 12v signal to turn on the amp. Nothing more. So in theory, couldn't you just take a mini plug from the amp and cut the other end off and run the bare wire directly into the Clarion? Interesting as I have never tried it but I can't see right now why it wouldn't work.
  • bknauss
    bknauss Posts: 1,441
    Where would this equipment be placed? Car audio equipment is much more resilient to heat, humidity, etc than home audio. Just something to think about.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • glemay
    glemay Posts: 574
    Toxis,
    I was thinking the same thing. So I figured the pre-outs on the back of a car deck would do the same as a home theater receiver, right? Well I disconnected the control wire and turned the car deck on and the Clarion wouldn't turn on. Now if the pre-outs on the Denon can somehow turn the amp on then I'll be all set.
    Bknauss,
    The Denon is down inside the cabin. As for the Clarion I could set it up inside the cabin or up on the flybridge.
    Thanks, keep it coming!
    Gerald
    Main System:
    Second System:
  • PolkThug
    glemay, just get a toggle switch from radio shack and put in on a wire between the battery and the amp, no big deal, when you want the amp/subs on, you just flip the switch.
  • glemay
    glemay Posts: 574
    Polk Thug,
    Sounds great, thanks! Now we will need to decide on a driver and get a box. What would you guys recommend for our application? The clarion amplifier will put out 380 Watts RMS when bridged I think.
    Gerald
    Main System:
    Second System:
  • Airplay355
    Airplay355 Posts: 4,298
    whats your price range?
  • glemay
    glemay Posts: 574
    In all honesty, I don't really know what our price range is. Hmmm... Let start at say 300$ CDN for driver and box and see what we can come up with and take it from there.
    Gerald
    Main System:
    Second System:
