Polk Magifi Max volume adjustment
Ken_Yeung
Properly I was posting my question in a wrong place so I repost it here again. Apologise.
Just come up with a strange situation. I set up my current Polk Magifi Max with my new Sony TV. It works properly for a night but not for the following day. After hours of trials, the sound bar works but when I try to adjust the volume, the sound bar reacts with no sound but not turn off. If I turn it off and turn it on again, it works again. The strange point is even when I use my TV remote controller, the sound bar also reacts with no sound immediately. Has anyone come across with similar situation? Appreciate all your thought and advice. Thanks.
Does the soundbar have uninterrupted AC power during the night?
I am not too sue, but if it is the case and how it can be solved?
Are you able to plug the soundbar into another AC outlet that remains powered?
