RTiA 6.5" driver Phase Plugs
I have 6 available for the RTi-A drivers if anyone is interested, just PM.
$55 /pair shipped US-48 ONLY
    xschop Posts: 5,165
    Typo. Should be $45 per pair shipped US-48 ONLY.
  • gp4jesus
    gp4jesus Posts: 2,019
    edited September 2022
    For anyone who cares in addition to xschop (thanks again, Rob) here’s a “foamed*” & “plugged” RTi A7 mid…
    …carefully hand tighten each screw 2-3 turns like a cylinder head…
    …mounted in its home w/painted trim ring and Trey’s diffraction pad.
    *per Garden Stater’s Foam thread
    *all connected w/Premiere ICs
  • gp4jesus
    I tested the upgrade listening to Dave Grusin's "Discovered Again" on Sheffield. SQ improvement well worth the effort!
    I heard sounds and music details I did never heard before! "Plugging" in addition to "foaming" the frames are both worthwhile. For any music lover using RTi or RTi A series speakers, get in touch w/ the man - Xschop!
    xschop Posts: 5,165
    Bump for more RtiA plug mods on the horizon.
    xschop Posts: 5,165
    edited August 2024
    If you have crappy midrange, the loose (and brittle) dustcaps are the culprit. I pulled them off by fingernails too easily and the edges where crumbly. One was dry-rotted and partially detached from glue....
    Post edited by xschop on
    xschop Posts: 5,165
    1 single drop wintergreen oil to capful olive oil is the sweet spot for fixing these dried out surrounds...
    pitdogg2 Posts: 27,045
    What does wintergreen oil bring to the party?
  • gp4jesus
    edited August 2024
    xschop wrote: »
    From which container did you use the cap to measure? Maybe a tsp? EVOO😂?
    Related note: Sunfire recommends for their “True” sub signature models, once annually rub some mink oil on both the driver & passive radiator surrounds.
    xschop Posts: 5,165
    These will be back on their way to GA Monday.
  • gp4jesus
    edited August 2024
    No rush.
    I much prefer “Quality over quickly.”
    Sorry for forgetting to tell you: do NOT sweat the existing Armacell. Upon return I need to “foam” them before returning them to their closure.
    1K thanks. Please PM return $hipping.
    Tony
    xschop Posts: 5,165
    edited August 2024
    It brings a minty-fresh breath of suppleness. I tested a few solutions/concentrations and the isopropyl alchol dries up too quickly.
    Looking forward to the center channel pics.
  • gp4jesus
    1K thanks Rob for your knowledge & expertise.
    Update for the drivers* pictured in the Aug 17th post: completed driver side Foaming, Sep 8th afternoon. A couple of the “Joys” of home owership has sidelined returning the same* to their Center speaker closure😢.
    Pics to follow on my CSi A6 mod thread.
  • gp4jesus
    https://forum.polkaudio.com/discussion/175612/tri-amped-csi-a6#latest
    No tweak last Saturday. My RTA (Behringer DEQ-2496) went belly up since the last time I used it😢
    xschop Posts: 5,165
    RTiA 5.25" midranges in process...
    These will also need 0.180" shorter base phase plugs. The 50% Alcohol with Wintergreen is perfect for soaking dust cap perimeters and restoring the butyl surrounds on these without worrying about damaging them....
