Sweet....
I'd be all over that!
Yup my 15tl's would be jealous but if I was closer I'd be on it for that price fer sureRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Could I drop the 8TL drivers in a set of those? Or only have to use 6510's?Don't take experimental gene therapies from known eugenicists.
Well... I mean um well, you .... you can do whatever your little heart desires. -
If a black pair like that popped up in these parts, I'd bite. I enjoy the 8TLs but wish the tweeters were 6-8" higher.Don't take experimental gene therapies from known eugenicists.
If you can find black paint...Gustard X26 Pro DAC
Yes, quite rare that black paint.
Does black spray-bedliner count?Don't take experimental gene therapies from known eugenicists.
Just trowel some tar on them
Beats delaminated oxidized vinyl quandary, no?Don't take experimental gene therapies from known eugenicists. -
Iirc, a cinder block is 8 in- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Anyone spiked cinder blocks?Don't take experimental gene therapies from known eugenicists.
Is that like spiking a football?
Alot of Kool-Aid was spiked the past couple years.Don't take experimental gene therapies from known eugenicists.
mhardy6647 wrote: »Is that like spiking a football?
Yes! -
I used to spike my hair. Does that count?
Only if you stand on your head.
