Vintage JVC QL-Y5F turn table
acmf74
acmf74 Posts: 937
edited July 2022 in Electronics
Hi Guys,
When I start playing a record the arm will not raise and automatically and leave the rest-clamp. In order for it to move I need to give it a gentle tap. But when I do hit stop it automatically goes back to the rest clamp. Does anyone know what adjustments I may need to do?
Kind regards,
  • jdjohn
    jdjohn Posts: 3,415
    That turntable has an 'electro-dynamic servo control tonearm', which utilizes integrated chips (ICs), and magnetic fields to move the arm up-and-down, and left-and-right. Did this just start suddenly, or had it sat for awhile unused?
    gudnoyez Posts: 8,183
    edited July 2022
    https://www.vinylengine.com/library/jvc/ql-y5f.shtml
    In case you havent seen this yet.
  • acmf74
    acmf74 Posts: 937
    I use the TT intermediately and this just started happening.
    Thanks for the link.
  • jdjohn
    jdjohn Posts: 3,415
    Since it works when you give it a tap, maybe it just needs a little cleaning inside the tonearm mechanism.
  • acmf74
    acmf74 Posts: 937
    yep! just needed a little compressed air thanks
  • jdjohn
    jdjohn Posts: 3,415
    Cool...let's hope that's all it needed.
