Citation 21 pream and Marantz 55q eq
ausol3
Hi guys!
I just purchased the Citation, trying to connect it withthe Marantz eq, according with the eq manual. But it get some problems I cant record from the CD player nor the turntable.
Thanks in advance for any tip.
Have a good weekend
Have a good weekend
Best Answers
Hello,
Welcome to Club Polk. Is it the Marantz EQ551 equalizer that you have? -
I found this is in the owner's manual:
Answers
Yes, I wrote it wrong
Tha.nks for your answer
Do you want to be able to record using the changes made by the EQ? Boost the low frequencies, for example?
Yes, I do. I was able to do it with my previous preamp.
Thank you for your answer! I'll try it later and let you know. I saw in YouTube, to connect the preamp in the Tape 2 out/in sockets.SeleniumFalcon wrote: »I found this is in the owner's manual:
I found this in the user´s manual as well. But nothing happens
Now I managed to get sound of the Citation, wtihout using the eq. That's not the idea. I can´t figure otu what I'm doing wrong!
In order to have the EQ effect the recording you have to connect the tape deck to the EQ using #3 connected to the output of the deck and #4 to the input of the deck.
It's what I did. But the HK manual says a different thing.
Thanks for your help -
From the manual:
SeleniumFalcon wrote: »From the manual:
SeleniumForce.
That what's I've been doing all the time. But it seems it doesn't work with the Citation XXI.
As I said I followed the Citation ownwer manual, and nothing happens. The Eq band bars goes up and down, but no sound at all. When I plug in thw tape deck and th Cd plawer everything works flawlessly.
Hi group!
Finally I came up to a solution. Plugged the CD player to the In socket and the out to IN in the tape 2 in the preamp. Then the tape deck to the Tape sockets in the preamp. I have to test the recording department. But I don't have blank tapes right now. I sounds wonderful. Thanks for all your time and help.
Have nice Sunday and wonderful week. -
I'm glad you got everything working.
