finishing a sub box
Airplay355
what are some good finishes to put on a sub box? its for a car so it doesnt have to be too elaborate. can you paint mdf easily?
Post edited by Airplay355 on
Trey (AKA Sid, AKA Vr3MxStyler2k3) used spray on truck bed liner... nice, mat black pebbled finish to a pair of his homebrew speakers.More later,
Tour...
Vox Copuli
that is fooking amazingly great idea
Never used it...
Yet...I got a can though...
I used PE's grill cloth and spray paint...
The truck bed liner is great, just the wrong time of year to use it...wait till it gets warmer...for a better finish...
Make sure you spray paint the enclosure a good one time over for a base coat though- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
My bad.... I thought I remembered you used the spray on a pair of towers you built...Originally posted by Vr3MxStyler2k3
Never used it...More later,
Tour...
Vox Copuli
I plan to...just to cold right now to give it a go...
They recomend like 60-95 degrees...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
And if the can said to jump off a bridge would you?:D
I painted these when it was like negative 15 celcius with trunk bed liner. The instructions are for losers!
Graham -
Call me a L 7 and give me a parachute...
OUCH- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
should you sand first to rough up the surface?
MDF edges like to absorb paint so it should be primed first. I did sand my box first with 80 grit.Graham
what do you use for primer? and did you sand the edges to curve them alittle or you just got a slightly curved finish after spraying on the liner?
He used a router- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
No router on those speakers above. To get the rounded look I used 40 grit sand paper followed by 80 grit on the edges. I used a latex primer aswell.Graham
Ah, dude - u got it really even for just using sand paper...awesome work!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thanks Sid, but the truck liner is idiot proof. It fills in the small imperfections from the sandpaper and screws.Graham
Thats good to hear!
I bought some to use on some small shelves I made that are 'extentions' to my surround shelves to hold movies and such...
Cant wait to give it a go!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
how'd you make sure you get an even coat?
It tells you how to on the can...
Like 6-8" back...evenly spraying it across the surface...
Once you get a can...u'll see...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
good, i like idiot proof things lol
