What cable and inputs should I use?
I moved to a new house with Polk wall speakers. I can’t figure out what cables to use to connect my TV to these input jacks on the wall. 48cm7knmocmg.jpeg
Please help!
Answers
    pitdogg2 Posts: 27,187
    edited July 2022
    Bare wire, spades or banana plugs. Those appear to be 5 way binding posts.
    Your receiver or amp would connect a speaker cable to those.
  • I tried these banana plugs but they were too large. Amazon Basics 16AWG Speaker Cable Wire with Gold-Plated Banana Tip Plugs (4mm) - CL2 - 99.9% Oxygen Free - 6-Foot https://a.co/d/6Qdg6TV
    Can you suggest another item?
  • rooftop59
    rooftop59 Posts: 8,120
    You should be able to just untwist the metal nuts and shove the bare wire in the hole and then twist it back tight. You don’t need banana plugs…
    Game Room 5.1.4:
    Bedroom 2.1
    mhardy6647 Posts: 35,165
    rooftop59 wrote: »
    Out of context, that's like an R-rated reply. :#
  • rooftop59
    rooftop59 wrote: »
    Whose got metal nuts? Git yer mind outta the gutter doc!
    Game Room 5.1.4:
    Bedroom 2.1
    audioluvr Posts: 5,977
    Can you imagine trying to explain that to the TSA! :D
  • OleBoot
    OleBoot Posts: 3,135
    rooftop59 wrote: »
    rooftop59 wrote: »
    Arnie
    F1nut Posts: 51,905
    I take "too large" to mean the banana plugs didn't fit entirely into the binding post hole and not that they were too wide to fit. That's because the binding posts on the wall plate are total crap.
