What cable and inputs should I use?
speakernewspeaker
I moved to a new house with Polk wall speakers. I can’t figure out what cables to use to connect my TV to these input jacks on the wall.
Please help!
Please help!
Answers
Bare wire, spades or banana plugs. Those appear to be 5 way binding posts.
Your receiver or amp would connect a speaker cable to those. -
I tried these banana plugs but they were too large. Amazon Basics 16AWG Speaker Cable Wire with Gold-Plated Banana Tip Plugs (4mm) - CL2 - 99.9% Oxygen Free - 6-Foot https://a.co/d/6Qdg6TV
Can you suggest another item?
speakernewspeaker wrote: »I tried these banana plugs but they were too large. Amazon Basics 16AWG Speaker Cable Wire with Gold-Plated Banana Tip Plugs (4mm) - CL2 - 99.9% Oxygen Free - 6-Foot https://a.co/d/6Qdg6TV
You should be able to just untwist the metal nuts and shove the bare wire in the hole and then twist it back tight. You don’t need banana plugs…
Out of context, that's like an R-rated reply.
Can you imagine trying to explain that to the TSA!
Whose got metal nuts? Git yer mind outta the gutter doc!
Arnie -
I take "too large" to mean the banana plugs didn't fit entirely into the binding post hole and not that they were too wide to fit. That's because the binding posts on the wall plate are total crap.Political Correctness'.........defined
