Flexible/Bendable Power Cords
jdjohn
I know that a lot of the best power cords are as thick as garden hoses (and quite stiff), but I'm wondering if there are any recommendations for power cords that are more flexible, and still able to handle high current loads for, say, power amps. To further clarify, I'm talking about cords that go directly from the wall to the amp.
Thanks in advance for any input!
Depends what you mean by bendable. My Shunyata power cords, while thick, are bendable enough for my rack and gear.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I have also found that some of the Shunyata cables that I have (Delta and Alpha series) are pretty flexible compared to other power cables I have owned: Pangea and PS Audio. Another cable depending on budget are Cullen cables. The Gold series and Crossover series are pretty flexible.2 Channel
Pre: Bryston BR20
Amp: Buckeye NCx500
Speakers: Polk L200
Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90
Amps: Buckeye NC502
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
Supra lorad
Duelund dca- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
PS Audio AC series are really great (at least until you get to the AC-13)"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Supra lorad
Duelund dca
Seconded; these are wonderful cables and won't break the bank either -
Pangea makes excellent power cables and they are flexible. I have (1) AC-9 MKII and (2) AC-14 MKII SE's and (1) AC-14. I have only installed the AC-14 in the office rig. The others are waiting to be installed in the main rig.
Audio Advisor has some demo units right now, for a little bit of savings. The new generation of cables uses Cardas copper.
Excellent bang for the buck and they concentrated on making them a bit more flexible than some of the other garden hoses out there.
P.S. the demo units right now are excellently priced. Less than I paid a month ago or so.
P.S.S. I bought a demo AC-14 and it was like brand new.....Post edited by heiney9 on"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
AC-14 is not flexible, imo.
And the AC-9 can be used as a weapon.
The duelund dca can do a hard 90 right of the connector side it is a simple 3 wire braids with no shielding etc- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I started with Pangea. After I tried an entry level Shunyata Venom cable I replaced all the Pangea cables. Also, the AC9 and AC14 cables I had 10 years ago were not flexible.Lumin X1 file player, Westminster Labs interconnect cable
If you're trying to do a 90* or more bend, then no. The OP asked about being flexible. In my use the AC 14 is much more flexible than most. The AC 9 is less so for sure.
Had the Op stated he needed to bend it around 90* I wouldn't have recommended."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
10 years is a long time to improve a cable. They had at least 2 revisions and may be 3 in that time."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Thanks for all the input. My current go-to for the amp is a PS Audio Statement cord, which is about 7/8" thick, and needs almost 8" in order to make a 90-degree turn. I would not want to get whipped with it."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
FWIW the sharpest bend you can get with a Pangea ac9 is 7". They are garden hosed sized cables that are miserable to work with and aren't even remotely close to being flexible.
These are flexible.
https://forum.polkaudio.com/discussion/196457/3-2m-mit-z-chord-power-cables-very-good-cond
Those do look nice, but I think I'm going to try the Supra LoRad since I already have Supra for speaker cable and RCA I/C."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Another vote for Cullen cables. Have a couple of them.
Probably old news here, but Cullen Cables 'migrated' to Wyred 4 Sound, although they seem to have lost their identity there (i.e., I don't see any products specifically labeled 'Cullen').
From the Cullen Cable website:
"Effective immediately I will be merging the Cullen Cable Brand with Wyred 4 Sound. You will find all my current products migrated over to the Wyred 4 Sound site (www.wyred4sound.com ).""This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Yeah if you’re gonna get the Pangea ac-9 you’ll need to go longer lengths. I’ve had both .5m and 1m cables and neither were flexible or easy to manipulate. I ended up needing 1.5m to plug my amp into my PC bc of the turn it needed. With one of the ac14’s I had to turn the inlet on my player up side down so it’d plug in, may have done it on my amp too. Moral of the story: Their longer cables are easier to work with👍Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
