Flexible/Bendable Power Cords
I know that a lot of the best power cords are as thick as garden hoses (and quite stiff), but I'm wondering if there are any recommendations for power cords that are more flexible, and still able to handle high current loads for, say, power amps. To further clarify, I'm talking about cords that go directly from the wall to the amp.
Thanks in advance for any input!
  • BlueFox
    BlueFox Posts: 15,250
    Depends what you mean by bendable. My Shunyata power cords, while thick, are bendable enough for my rack and gear.
  • sgmsmg
    sgmsmg Posts: 556
    I have also found that some of the Shunyata cables that I have (Delta and Alpha series) are pretty flexible compared to other power cables I have owned: Pangea and PS Audio. Another cable depending on budget are Cullen cables. The Gold series and Crossover series are pretty flexible.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
    VR3 Posts: 29,539
    Supra lorad
    Duelund dca
    EndersShadow Posts: 17,719
    PS Audio AC series are really great (at least until you get to the AC-13)
  • motorstereo
    motorstereo Posts: 2,359
    VR3 wrote: »
    Supra lorad
    Duelund dca
    Seconded; these are wonderful cables and won't break the bank either
    heiney9 Posts: 25,492
    edited July 2022
    Pangea makes excellent power cables and they are flexible. I have (1) AC-9 MKII and (2) AC-14 MKII SE's and (1) AC-14. I have only installed the AC-14 in the office rig. The others are waiting to be installed in the main rig.
    Audio Advisor has some demo units right now, for a little bit of savings. The new generation of cables uses Cardas copper.
    Excellent bang for the buck and they concentrated on making them a bit more flexible than some of the other garden hoses out there.
    P.S. the demo units right now are excellently priced. Less than I paid a month ago or so.
    P.S.S. I bought a demo AC-14 and it was like brand new.....
    Post edited by heiney9 on
    Clipdat Posts: 13,100
    AC-14 is not flexible, imo.
  • maxward
    maxward Posts: 1,714
    And the AC-9 can be used as a weapon.
    VR3 Posts: 29,539
    The duelund dca can do a hard 90 right of the connector side it is a simple 3 wire braids with no shielding etc
  • BlueFox
    I started with Pangea. After I tried an entry level Shunyata Venom cable I replaced all the Pangea cables. Also, the AC9 and AC14 cables I had 10 years ago were not flexible.
    Clipdat wrote: »
    If you're trying to do a 90* or more bend, then no. The OP asked about being flexible. In my use the AC 14 is much more flexible than most. The AC 9 is less so for sure.
    Had the Op stated he needed to bend it around 90* I wouldn't have recommended.
    BlueFox wrote: »
    10 years is a long time to improve a cable. They had at least 2 revisions and may be 3 in that time.
  • jdjohn
    jdjohn Posts: 3,380
    Thanks for all the input. My current go-to for the amp is a PS Audio Statement cord, which is about 7/8" thick, and needs almost 8" in order to make a 90-degree turn. I would not want to get whipped with it.
  • motorstereo
    FWIW the sharpest bend you can get with a Pangea ac9 is 7". They are garden hosed sized cables that are miserable to work with and aren't even remotely close to being flexible.
  • jdjohn
    jdjohn Posts: 3,380
    Those do look nice, but I think I'm going to try the Supra LoRad since I already have Supra for speaker cable and RCA I/C.
  • DaveHo
    DaveHo Posts: 3,583
    Another vote for Cullen cables. Have a couple of them.
  • jdjohn
    jdjohn Posts: 3,380
    Probably old news here, but Cullen Cables 'migrated' to Wyred 4 Sound, although they seem to have lost their identity there (i.e., I don't see any products specifically labeled 'Cullen').
    From the Cullen Cable website:
    "Effective immediately I will be merging the Cullen Cable Brand with Wyred 4 Sound. You will find all my current products migrated over to the Wyred 4 Sound site (www.wyred4sound.com )."
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    Yeah if you’re gonna get the Pangea ac-9 you’ll need to go longer lengths. I’ve had both .5m and 1m cables and neither were flexible or easy to manipulate. I ended up needing 1.5m to plug my amp into my PC bc of the turn it needed. With one of the ac14’s I had to turn the inlet on my player up side down so it’d plug in, may have done it on my amp too. Moral of the story: Their longer cables are easier to work with👍
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
