Weather Proof Subwoofer?
glemay
glemay Posts: 574
edited February 2005 in Speakers
Hi,
Do you guys know of any subwoofers that are able to withstand the weather, humidity, sunlight, moisture and fluctuating temperatures?
Gerald
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Post edited by glemay on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I open my slider, my sub never leaves the house. I don't think any speaker / sub made from wood would work outside very long.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Frank Z
    Frank Z Posts: 5,860
    SVS!;)
  • disneyjoe7
    Just for you Frank ;)
    Here we go again.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Frank Z
    WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!
    VR3 Posts: 29,422
    I reckon if you got like a CA or PA driver, in a weather proof enclosure like used on outdoor speakers... it could work...
    I would try to put it in the shade or something over it...
    I wouldnt use a HA driver though
  • Frank Z
    Oh great...Sid's makin' **** up again.:D
    VR3 Posts: 29,422
    I'm sure your a Genius In France! (great parody song by the way)
  • Frank Z
    Me and Jerry Lewis!
  • bikezappa
    bikezappa Posts: 2,463
    I like to sit in my out door hot tube and listen to music. I put 2 speakers in trees about 30' away, 30 ' apart and 10' high. I also put an AR sub out in the woods centered between the 2 speakers. I located the sub on a metal table 2' high and wrapped fine mesh wire around the table and sub. I then covered the sub and table with a black heavey water proof tarp. I located the sub behind a pine tree. That was 2.5 years ago in NH and the bass is still there. The sub turns off and on depending if there is a signal from the reciever which is located in the basement. The remote controlls the reciever with a RS IR to RF converter. All the wires were placed 3" under the grass between the tub and woods.
    The imaging and sound staging are incredable. I know because
    I have SDAs. There are NO room reflections. The sound changes with the weather. Right now the snow and ice cover everything and the sound is very bright and reflective.
    I will upgrade this summer to a more powerful reciever and better speakers.
    Any recommenations for the best outdoor speakers?
  • disneyjoe7
    I heara bikezappa,
    I think this is all fine with one think in mind, it's a complete loose down the road. Meaning $1000 spent out there is a completely gone 4 years down the road, when weather takes the toll.
    I'm thinking of adding a TV to my covered porch, would I spend $350 for a nice Sony no maybe something like a $180 RCA or ? because when it goes it's trash, then back to store for another TV.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • bikezappa
    I understand, it was a risk.
    I only paid $300 for the Ar sub.
    My biggest fear was damage from the mice and rodents, but I have checked the condition every few months and it looks OK. Maybe the 5 outdoor cats keep the rodents down to a minium. The trap and the table keep everything dry.
    I wouldn't put a TV out in the wild because of the changes in temperature and thermal shock during start up.
    Anybody recommend some great outdoor speakers?
    Cambridge Soundworks????
  • disneyjoe7
    >>I understand, it was a risk.<<
    Yes, a complete throw away, down the road.
    >>The trap and the table keep everything dry.<<
    I'm more worried about the mold issues.
    (Could be the Florida in me)
    >>I wouldn't put a TV out in the wild because of the changes in temperature and thermal shock during start up.<<
    I won't either, but a covered porch 3 / 4 year life ok.
    >>Anybody recommend some great outdoor speakers?<<
    Polk outdoor, seem fine for me.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Airplay355
    Airplay355 Posts: 4,298
    build a sturdy box, find a driver that can handle the weather, and just keep the amp inside. use a long speaker run to connect them. no biggie.
  • glemay
    glemay Posts: 574
    That's what I was thinking. But I want to use a 12V amplifier that I got laying around, but how do I use it with the Denon AVR-2805 when there is no control wire to signal the amplifier to turn on?
    Gerald
    Main System:
    Second System:
  • Airplay355
    leave it on all the time
  • glemay
    glemay Posts: 574
    How would I leave it on? I don't know if that would really be a good idea because it could be on for a week before we go back out on the boat. and my dad wouldn't want it on 24/7 since it would be pulling from the battery all day long.
    Would I be able to put it on a switch or something and wire it up so when the Denon turns on the Clarion will too?
    Gerald
    Main System:
    Second System:
