Maggie LRS scheduled to be delivered this Friday
  • pearsall001
    pearsall001 Posts: 5,222
    The jury is still out...a lot more involved then setting up a pair of box speakers. A huge learning curve for sure.
    A different sound signature with every little new placement!
    It's a lot of fun though going thru the set-up paces.
    More to follow.
  • jbreezy5
    jbreezy5 Posts: 1,141
    I’ve had a similar experience setting up the ML ESLs.
    If you haven’t already, try setting up the LRS’ at 90 degree angle to the floor so they are vertically upright.
    This helped get a flatter frequency response with the mid/high-frequencies, for my ‘stats.
  • maxward
    maxward Posts: 1,670
    Yes. Do that^^^. And try tweeters in vs out.
  • Emlyn
    Emlyn Posts: 4,620
    Placement in the room and in relationship to a single seat listening spot to find the best stereo sweet spot is critical with Magnepans. Having said that, I've also used mine in a home theater setup with a couple good subwoofers and an excellent center speaker in the mix and they do really well to spread the sound around the front soundstage as well as around the room because of their bipole design. They need lots of room to breathe.
  • pearsall001
    Thanks for all the recommendations guys.
    Now that I'm feeling better after my stint with Covid I can focus on getting the LRS set up & sounding their best. A complete 180 vs setting up a box speaker.
    More to follow.
  • jbreezy5
    Don’t push too hard post-Covid, the fatigue sometimes returns. At least for me it did.
  • pearsall001
    jbreezy5 wrote: »
    I know... not out of the woods just yet. Still feeling pretty good right now & spend some time with trying different placement scenerios.
    Holy craps the littlest movement gives you a totally different sound signature! Having fun though. 🎶🎶🎶
