Audiolund Cables
VR3
So for those following the Carolina gathering thread, we tried the digital cable at the tail end of the event with excellent results.
I decided to order a set of their Xtreme Rca interconnects, which arrived yesterday.
Audiolund uses Duelund DCA wiring in their products. Their highest tiers uses all silver or a mix of duelund dca with silver. I opted for no silver as I have found that to not work in my system.
Either way, these cables are insanely well built. I plan to listen to the rca ics today!highly recommend checking out the website.
The digital cable made quick work of the wire world digital cable I had been using.
https://audiolund.com/product/xtreme-series-interconnect-rca/
I am in the market for an upgraded 75 ohm digital cable. I've always been an MIT guy, but they are so expensive and used is few and far between. I have been using a Blue Jeans cable for years, but it's time for something new.
Looking forward to your impressions, specifically on the digital cable. Build looks fantastic
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Yeah I am using the xtreme digital cable, I'll post more thoughts on that as well. I plan to listen more before installing the analog cables.
All prices are Singapore dollars so it's a little less usd- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
They have the same look as Acoustic Zen absolute or matrix. I wonder if they use the same wire or supplier?Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Is "Western Electric vintage sound" like saying their non-Silver cables are warm and tube like and their Silver based cables aren't?
The tin plated copper duelund wire has an amazingly musical sound to me. Great tone, texture detail, bass... Staging, great layering.
He is using the duelund dca polycast wiring versus the oil baked cloth...
I am very curious to compare the ics to my oil baked cloth, Unshielded duelund ics with the duelund rca connectors...
My understanding is they are all hand made, beyond the duelund wire and silver wire he uses, he uses dampening and shielding and then installs in a tech flex
The ics use 2x 16 GA and a x 20 GA duelund polycast wiring per leg, 8 wires per cable or 16 per set.
This is the 16 awg wire https://audiolund.com/product/z2-duelund-16awg-dca16ga600v-tin-plate-copper-hookup-wire-600vdc-rated/- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The digital cable has an absolutely unmistakable clarity to the top end. Listening now and it is the same as the first time I fired it up with Tom here. On the first song, the high frequencies are so clean and clear, layered... We both heard aspects to a song I am very familiar with and we listened to multiple times that day.
Just remarkably clear top end and low end details... Fantastic staging as well- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Standard cloth baked duelund versus audiolund
So initial impressions are very positive. Similar top end and low end but extremely good midrange and weight which was already very good on the stock duelund. Just intense imaging. I really enjoyed it
Definitely looking forwards to listening more tomorrow- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Just hooked up the ethernet cables and the difference is... Surprising to say the least. I honestly expected nothing but the air in the high frequency is... Kind of startling.
Very impressed with all of the cables I have tried so far
I listened about 5 hours yesterday, I was texting folks about my impressions during the listening sessions but I am honestly blown away by how different the system sounds with these cables. They truly changed every aspect of the setup. I went in expecting truly no change in sound to really having to sit down and take it all in. The price is not outrageous, each cable is around $150 each... tremendous value- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I think I might give the Ethernet cables a try. They look built.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
You won't be disappointed. I changed the cable from the modem to the router and from the router to the streamer- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Well..... After 6 or so hours of labor... 4 x 2.5 inch holes, pvc pipe sleeves...
Speaker wires are installed!
Can you pull the speakers out a little further for your near field listening times? Looks great for such a tight area to work in.
Thanks man, definitely an endeavor!
I started by rolling the speakers into place snd then running the cables to the cubby.
Literally the exact length of what i needed for it all to work, hardly any extra... 15 ft- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Looks great. Thats a lot of work!Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Thanks man
I really enjoy the sound of everything.
My thoughts on the audiolund speaker cables
*silence, zero noise... Whatever noise floor I had left appears to be eerily gone... It is hard to explain
*authorative bass
*the top end is free of any artifacts, sibilance... Just a very smooth presentation
I am constantly seeking out forms of compression, artifacts and distortions and this is honestly the first time I can say I'm very close to that goal.
The speaker cables removed the last bit that I sensed. I really like duelund wire and I really like these cables that audiolund makes.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Power and network cables
I want a larger view of your rack Trey. IIRC it’s got a interesting configuration"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
There's a top shelf not in the picture that has the network stuff and the ht gear is on the right. Not an up to date of as well, I secured all of the dangling power cables and such- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
