Audiolund Cables
VR3
VR3 Posts: 29,554
edited June 2022 in 2 Channel Audio
So for those following the Carolina gathering thread, we tried the digital cable at the tail end of the event with excellent results.
I decided to order a set of their Xtreme Rca interconnects, which arrived yesterday.
Audiolund uses Duelund DCA wiring in their products. Their highest tiers uses all silver or a mix of duelund dca with silver. I opted for no silver as I have found that to not work in my system.
Either way, these cables are insanely well built. I plan to listen to the rca ics today!highly recommend checking out the website.
The digital cable made quick work of the wire world digital cable I had been using.
https://audiolund.com/product/xtreme-series-interconnect-rca/w5f5c7l1mv9w.jpg
    heiney9 Posts: 25,530
    I am in the market for an upgraded 75 ohm digital cable. I've always been an MIT guy, but they are so expensive and used is few and far between. I have been using a Blue Jeans cable for years, but it's time for something new.
    Looking forward to your impressions, specifically on the digital cable. Build looks fantastic
    VR3 Posts: 29,554
    Yeah I am using the xtreme digital cable, I'll post more thoughts on that as well. I plan to listen more before installing the analog cables.
    All prices are Singapore dollars so it's a little less usd
  • erniejade
    erniejade Posts: 6,321
    They have the same look as Acoustic Zen absolute or matrix. I wonder if they use the same wire or supplier?
  • Emlyn
    Emlyn Posts: 4,837
    Is "Western Electric vintage sound" like saying their non-Silver cables are warm and tube like and their Silver based cables aren't?
    VR3 Posts: 29,554
    The tin plated copper duelund wire has an amazingly musical sound to me. Great tone, texture detail, bass... Staging, great layering.
    He is using the duelund dca polycast wiring versus the oil baked cloth...
    I am very curious to compare the ics to my oil baked cloth, Unshielded duelund ics with the duelund rca connectors...
    VR3 Posts: 29,554
    edited June 2022
    erniejade wrote: »
    My understanding is they are all hand made, beyond the duelund wire and silver wire he uses, he uses dampening and shielding and then installs in a tech flex
    The ics use 2x 16 GA and a x 20 GA duelund polycast wiring per leg, 8 wires per cable or 16 per set.
    This is the 16 awg wire https://audiolund.com/product/z2-duelund-16awg-dca16ga600v-tin-plate-copper-hookup-wire-600vdc-rated/
    VR3 Posts: 29,554
    The digital cable has an absolutely unmistakable clarity to the top end. Listening now and it is the same as the first time I fired it up with Tom here. On the first song, the high frequencies are so clean and clear, layered... We both heard aspects to a song I am very familiar with and we listened to multiple times that day.
    Just remarkably clear top end and low end details... Fantastic staging as well
    VR3 Posts: 29,554
    Standard cloth baked duelund versus audiolund
    VR3 Posts: 29,554
    So initial impressions are very positive. Similar top end and low end but extremely good midrange and weight which was already very good on the stock duelund. Just intense imaging. I really enjoyed it
    Definitely looking forwards to listening more tomorrow
    VR3 Posts: 29,554
    Just hooked up the ethernet cables and the difference is... Surprising to say the least. I honestly expected nothing but the air in the high frequency is... Kind of startling.
    Very impressed with all of the cables I have tried so far
    VR3 Posts: 29,554
    I listened about 5 hours yesterday, I was texting folks about my impressions during the listening sessions but I am honestly blown away by how different the system sounds with these cables. They truly changed every aspect of the setup. I went in expecting truly no change in sound to really having to sit down and take it all in. The price is not outrageous, each cable is around $150 each... tremendous value
  • erniejade
    I think I might give the Ethernet cables a try. They look built.
    VR3 Posts: 29,554
    You won't be disappointed. I changed the cable from the modem to the router and from the router to the streamer
    VR3 Posts: 29,554
    Well..... After 6 or so hours of labor... 4 x 2.5 inch holes, pvc pipe sleeves...
    Speaker wires are installed!
    treitz3 Posts: 20,132
    Can you pull the speakers out a little further for your near field listening times? Looks great for such a tight area to work in.
    VR3 Posts: 29,554
    Thanks man, definitely an endeavor!
    I started by rolling the speakers into place snd then running the cables to the cubby.
    Literally the exact length of what i needed for it all to work, hardly any extra... 15 ft
  • erniejade
    Looks great. Thats a lot of work!
    VR3 Posts: 29,554
    Thanks man
    I really enjoy the sound of everything.
    My thoughts on the audiolund speaker cables
    *silence, zero noise... Whatever noise floor I had left appears to be eerily gone... It is hard to explain
    *authorative bass
    *the top end is free of any artifacts, sibilance... Just a very smooth presentation
    I am constantly seeking out forms of compression, artifacts and distortions and this is honestly the first time I can say I'm very close to that goal.
    The speaker cables removed the last bit that I sensed. I really like duelund wire and I really like these cables that audiolund makes.
    VR3 Posts: 29,554
    edited November 2022
    Power and network cables
    EndersShadow Posts: 17,723
    I want a larger view of your rack Trey. IIRC it’s got a interesting configuration
    VR3 Posts: 29,554
    There's a top shelf not in the picture that has the network stuff and the ht gear is on the right. Not an up to date of as well, I secured all of the dangling power cables and such
