Polk Reserve Series R700
OK guys, I did this with a construction knife blade. I plucked up the courage and tucked the ring. Got access to six mounting bolts. I unscrewed them and just took out the tweeter with my hand. It should be noted here that magnets are indeed present both on the speaker body and on the ring itself. But the ring is held mainly by adhesive tape along its diameter.
Huge thanks for your help!
Check the voice coil for continuity with a DMM, VOM, or VTVM.
That will tell you instantly if the tweeter is bad/dead (i.e., if it's the root cause of your no tweetage problem). It won't tell you whether the tweeter's working properly... but it'll give you valuable rule in/rule out information.
If you don't have a meter, you can, carefully (!) test the tweeter with two clipleads and a small battery (e.g., a 1.5 V "AA" cell). Connect the two clipleads to the tweeter terminals. Hold one cliplead to one battery terminal (ideally the "-" lead to the "-" terminal -- but it doesn't really matter), then quickly/briefly touch the other lead to the other battery terminal. As the circuit is "made", the battery will energize the voice coil, and the tweeter diaphram will move if the tweeter voice coil is intact. The result will be a small "tick" or audible static as the connection is made. DO NOT leave the tweeter connected the battery as current will be flowing through the voice coil, creating heat! A 1.5 V AA battery should be pretty safe -- but better safe than sorry!
A DMM has a high input impedance and can safely measure the DC resistance of the tweeter's voice coil with no concern for the well-being of a (good) tweeter.
PS If you don't have clipleads...well... heaven help you.
These speakers sound amazing. Very detail and an amazing punch low end.
This trend kind of took a different direction but is all good in the name of Polk fans.
The Amp noise is gone after a few on and off tries it went away power comes back silent and smooth once again.
CheersHTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
I've read nothing but good things about these speakers. I'm happy with my 2Bs, but I've got the itch to get a pair of these. Wish I had bought them when I had the discount code!Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Hi Vasyl777, if it's not prying (no pun intended) how did you blow out a fairly new tweeter in a high-end/high-res speaker? That's a little scary!
LR: Polk R600, SVS SB-2000 Pro, Marantz NR1200 pre, Emotiva BASX A2 amp, Denon 600NE CD, JVC L-A11 turntable.FR: Polk TSI-400, Polk PSW110 center, Polk R1 surrounds, Onkyo TX-NR656 receiver.Home office: Polk LS50, Yamaha NR-602 receiver, JVC KD-V100 cassette, Sony TC-558 R2R.In reserve: Technics SA-203 receiver"Y'know? To truly love some silly little piece of music, or some band, so much that it ... hurts." -
For the center channel I am between the R350 or the R400 not sure yet what to get but need to do it soon as the sale ends today.
I will also get the R900 for Atmos.
R400... stop procrastinating.
Ahhh the R400 have a 2 to 4 week lead time.HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
Then I will expect a detailed review in 3 to 5 weeks...
Done now is wait time.
Cheers
The R900 arrived last Wednesday no time to get them setup. Will try today, but not sure maybe I want to wait for the center so I don't have to do the calibration again.
Ahh tempted.
Cheers.HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
Could let’em break-in without calibrating while waiting for the center.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
Good point.
