Scratched mirror glass repair
F1nut
F1nut Posts: 52,008
Any of you have experience repairing scratches on mirror glass or recommend a repair firm? The scratches are not deep enough to feel with a fingernail.
At first I tried baking soda with water, dry mustard with vinegar and then Brasso. I didn't try toothpaste because I know it doesn't work.
I then I tried your standard automotive rubbing compound, nothing. Next I broke out my heavy duty buffing machine and 3M rubbing compound, which after multiple applications made a very minor improvement, but not enough to continue.
I saw some scratched glass repair kits online, but the reviews left a lot to be desired.
This is antique mirror glass, which is very thin and in part due to its larger size is valuable.
    mhardy6647 Posts: 35,242
    Did you try jewelers' rouge, or would that be too fine?
    Context (FWIW): BITD, I used a paste made with jewelers' rouge and distilled water to polish the gold "working electrodes" on an electrochemical molecular detector we used in the lab to a mirror finish.
    F1nut Posts: 52,008
    Ah yes I did and forgot to note that.
    sorry, that was my best shot.
    I wonder if an agent which can attack/solubilize glass (hydrofluoric acid or strong alkali leap to mind - although neither reagent is subtle nor pleasant to work with) might be capable of 'removing' the scratch if used extremely judiciously? Needless to say, I wouldn't try this with the valuable glass without beta-testing on some cheap scratched glass!
    F1nut Posts: 52,008
    Thanks Mark. I'm going to consult with my very reputable glass shop tomorrow. They do everything, but I doubt they'll touch this one due to the risk of breaking the very thin glass.
    F1nut Posts: 52,008
    The glass folks want to see it in person, so I'll take it over there. In the meantime, if anyone here stumbles upon this thread and has a suggestion please speak up.
  • jdjohn
    jdjohn Posts: 3,384
    edited June 2022
    You might take a look at Peek polishing paste. It has ground-up diamond dust in it, and is good for polishing non-porous surfaces. In the FAQs here: https://tripeek.com/faqs/ under the third bullet regarding surfaces, it includes "Eisenglass, mirrors, clouded glass and crystal, leaded glass" in the list. I use it for polishing faceplates on components, acrylic dustcovers for turntables, and turntable platter edges and/or inner/sub-platters where a belt might run. It comes in paste, liquid, and spray-on foam. I've only used the paste. Pretty handy stuff!
    You can find it on Amazon.
  • OleBoot
    OleBoot Posts: 3,135
    Some years ago I successfully restored a car windshield that had a maze of fine scratches caused by a rogue carwash with a kit from eastwood.com. Don't know how it would do on regular and thin glass. Did some of it by hand with their supplied "paste" and it worked with a gentle touch and a lot of elbow grease.
    edited June 2022
    Edit: ne'er mind. I looked it up. :p
    sorry!
    F1nut Posts: 52,008
    I'll look into the Peek and Eastwood products. Thanks guys.
  • Jstas
    Jstas Posts: 14,996
    The Eastwood kit, if it's the same one I remember seeing several years ago now is rated for the old non-safety glass in really old cars, like stuff before 1960.
    If so, that will likely do what you are looking for it to do.
    Expert Moron Extraordinaire
