How to reset Polk Assist smart speaker?
Answers
This is what worked for me to reset. From u/kex
To reset:- Hold down the mic mute button until the unit shuts off.
- You will have lights and a voice prompt telling you you are about to reset the unit (voice prompt didn't come up for me, but I kept holding it extra long).
- Then it will go dark, at that point you can release the button.
Am finding it difficult to reset my polk audio assistant
Am finding it difficult to reset my polk audio assistant after resetting
20 oz. hammerPolitical Correctness'.........defined
President of Club Polk -
"Am finding it difficult to reset my polk audio assistant"
Can you explain what your Assist is not doing? That way I can ask a friend at Polk for recommendations.
