Vintage tube amp for SDA-CRS
VSAT88
Anyone run a vintage tube amp on/with their SDA-CRS's ? If so please give me a suggestion of a good one to run them with. Was thinking a VT100?
I've used a couple of Conrad Johnson amps with great success...I plan for the future. - F1Nut
So mono block on each channel with a dreadnought?
Yes you can, or you should be able to.
I'm able to run my Aragon 8008bb on my 2.3tl's works wonderful. It has two massive torrid's one for each channel. -
I think there were a pair of VAS Citation EL-34 monos for sale on the forum.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
Yes, I saw one just the other day (8008) for sale and I almost jumped. I have the dreadnought all set up already. Was just contemplating other amps. Running an assortment now. A small tube amp ( Chinese modified) 50 wpc that does a very nice job at low volume levels. A Krell KSA 150 that will make the MW jump out of the box if I am not careful and a B&K Reference 2200. They all sound good but I always wanted to try a few mono blocks or a higher wattage tube amp on them. -
Hey thanks I will have a look.
