SDA-2a Speaker Grill Treelock or Peg needed
I am repairing a set from 1985.
I had built a slide-hammer to non-destructively remove the treelocks or speaker pegs.
The cabinet hole checks .450”
The ball diameter is .426”
I would be happy to buy one from a fellow member?
The slide-hammer worked quite well. The last peg was always broken...
Please help,
Baker in St Peters, MO
Answers
  • Gardenstater
    Gardenstater Posts: 4,804
    edited May 2022
    They have 7/16" ones on ebay. That slide hammer is really slick.
    https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=grille+pegs&_sacat=0
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Baker
    Baker Posts: 18
    Hey Gardenstater, thanks a bunch!
    Just bought them. Will let you know how it works out. Thought I might have to turn some...
    Slide-hammer was slick, thanks for the compliment.
    I considered building a jig to drill from inside the cabinet, and knock them out with a punch. Glad I built the hammer!
    After I’m done, I would be pleased to share the tool with members.
    pitdogg2 Posts: 27,343
    Parts express carried the exact size needed for years.
    That is a crazy cool tool!! 👍
    Those trees are a bear to remove.
  • Baker
    Baker Posts: 18
    Thanks Pitdogg2,
    I looked at Parts Express. The ones they currently carry are a little small.
    I initially tried to get under the flange of those treelocks with a pair of putty knives. It was clearly not going to happen...
    xschop Posts: 5,417
    That slide would've come in handy a few times. Nice V-block too. Get everything from PE you need at once, shipping just went up.
  • Baker
    Baker Posts: 18
    Good eye on that V-Block...
    Square, true, and central w/i .0002
    Yes, two tenths...
    Thanks xschop
  • Gardenstater
    Parts Express has them too but they have to be different and call them grill guides instead of grille pegs lol
    https://www.parts-express.com/Heavy-Duty-Grill-Guides-12-Pair-260-367
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
