SDA-2a Speaker Grill Treelock or Peg needed
Baker
I am repairing a set from 1985.
I had built a slide-hammer to non-destructively remove the treelocks or speaker pegs.
The cabinet hole checks .450”
The ball diameter is .426”
I would be happy to buy one from a fellow member?
The slide-hammer worked quite well. The last peg was always broken...
Please help,
Baker in St Peters, MO
Please help,
Answers
They have 7/16" ones on ebay. That slide hammer is really slick.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=grille+pegs&_sacat=0George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Hey Gardenstater, thanks a bunch!
Just bought them. Will let you know how it works out. Thought I might have to turn some...
Slide-hammer was slick, thanks for the compliment.
I considered building a jig to drill from inside the cabinet, and knock them out with a punch. Glad I built the hammer!
After I’m done, I would be pleased to share the tool with members.
Baker in St Peters, MO -
Parts express carried the exact size needed for years.
That is a crazy cool tool!! 👍
Those trees are a bear to remove. -
Thanks Pitdogg2,
I looked at Parts Express. The ones they currently carry are a little small.
I initially tried to get under the flange of those treelocks with a pair of putty knives. It was clearly not going to happen... -
That slide would've come in handy a few times. Nice V-block too. Get everything from PE you need at once, shipping just went up.Don't take experimental gene therapies from known eugenicists.
Good eye on that V-Block...
Square, true, and central w/i .0002
Yes, two tenths...
Thanks xschop -
Parts Express has them too but they have to be different and call them grill guides instead of grille pegs lol
https://www.parts-express.com/Heavy-Duty-Grill-Guides-12-Pair-260-367George / NJ
iFi nano iDSD DAC
iPurifier3
