RCMs
    SCompRacer Posts: 9,112
    edited May 2022
    FWIW, the edges of record label can get wet as the acrylic spacer discs have no edge seals. While you can adjust the depth of record into tank, as the record turns solution runs down onto the spacers.
    I like to keep the record labels dry as some react poorly to water and I like to put the record in a MOFI sleeve and back in the jacket after vacuuming. If you rack dry, no big deal, the label would dry.
    I have an old Groovemaster label saver. I just enlarged the hole to fit the spindle. Yeah, can only do one at a time. To clean more than one at a time, rather than DIY gluing O-rings to existing spacers, I purchased three pairs of WEWU Rounds label savers. Available for 7" and 12" records. I'll have to enlarge the holes to fit the spindle as the WEWU holes are 6.5mm, the shaft measures 6.9mm.
    https://www.amazon.com/gp/product/B08YP6CXTG/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
    WEWU Rounds label savers, available at Amazon.
  • Nightfall
    Nightfall Posts: 10,084
    edited May 2022
    Degritter is too expensive for just a RCM if you're not a doctor ;) the HumminGuru looks interesting I'll look into it.
    afterburnt wrote: »
    Village Idiot of Club Polk
    edited May 2022
    msg wrote: »
    I always wondered about the transducer frequency as well. It's one of those things people argue about and make cases for. One or more articles said the "wrong" frequency will damage your records. I don't remember which frequency was the right one in those articles.
    Doing research I came across this post at diyaudio.
    https://www.diyaudio.com/community/threads/diy-ultrasonic-record-cleaner-what-frequency-to-use.276858/
    "What Frequency to Use and more
    As a builder of Ultrasonic Cleaners (a former employee of Sonix4, now independent), I may offer a few insights.
    It is true, there have been no reports for damage to vinyl records using the mass-market, Chinese 40khz Ultrasonic Cleaners. They do make a good, inexpensive option for cleaning your Record Collection.
    The cavitation bubble formed by a 40khz unit is much larger and more powerful than those of a higher frequency (60khz, 80khz, 120khz, 135khz).
    When the cavitation bubble implodes, it releases a jet stream and heat. The larger bubble releases a larger amount of power and heat (10,000 degrees kelvin, according to scientific reports, in minuscule amounts).
    The 40khz cavitation bubble is too large to penetrate the record groove, but all ultrasonic cleaners rely on the jet stream to dislodge any debris.
    The smaller cavitation bubble of a higher frequency cleaner can form inside the groove, next to debris and dislodge it.
    Higher frequency Ultrasonic Cleaners generate MORE cavitation bubble than lower frequency units. More bubbles, more implosions, better cleaning coverage.
    I frequently get asked which frequency is the best for cleaning vinyl records. I recommend the following:
    If you collect albums that are in poor condition, such as mold or water damage, the the lower frequencies (40khz or 60khz) are the better option. (Many collectors buy from flea markets, estate sales, etc). If your collection is already in good condition (finger prints and dust), then the higher frequencies would better suit the collector (80khz, 135khz).
    Cleaning solution is vital. There are many formulas, but I personally recommend TergiKleen (or a formula similar) because it is archival and used by the Library of Congress for recorded materials.
    Carefully monitor the heat in the tank, also. Even though the Heater may turn off the heating element, the act of cavitation will continue to release heat, which will cause the solution to go above the cut-off point! Heat will warp and destroy vinyl records.
    To address the issue of cost, I say this: It costs me more than 3X for parts alone than what a Chinese Ultrasonic Cleaner costs! In my opinion, they are deliberately undercutting American Manufacturers.
    Hope some of this helps.
    -Louis
    Vibrato, LLC."
  • TroyD
    TroyD Posts: 13,124
    That is the same kit that I had....and Rick now has....
    Regarding the spacers.....I never had a label get wet (except for the one I dropped) using the spacers. IMO, the trick is to keep the fluid level just above the lead out groove.
  • Joey_V
    Joey_V Posts: 8,600
    @TroyD
    I’m still not completely convinced that US without actual scrubbing is complete. I think there’s something to be said about physical cleaning on top of US
    Just my opinion
  • aprazer402
    aprazer402 Posts: 3,388
    edited May 2022
    Joey_V wrote: »
    @TroyD
    Just my opinion
    So medically speaking:
    Ultrasonic : Radiation
    Physical Cleaning : Surgery
    Cleaning Fluid : Chemotherapy
    Get it All!!! :)
    txcoastal1 Posts: 13,513
    It all depends on the way you collect albums. I don't see a need of doing both if you are purchasing new vinyl or trading with someone who cares and handles their vinyl collections properly. That includes how you handle your vinyl collection.
    I've been with people who have cleaned their records and stored properly. When they lay that record down on their TT they will spin the player and run their brush then play. After playing they will run brush then put back into proper sleeves.
    If you are out there collecting from every where then using both types would be best, but once they are completes scrubbed, VAC'd and US...imho opinion that record would need to be either mishandled or played over and over again before needing the dual cycle.
    Just my .02
  • rooftop59
    rooftop59 Posts: 8,121
    This thread is a great reminder of why I’m never getting into vinyl! Suckers!!!
    Game Room 5.1.4:
    Bedroom 2.1
    Clipdat Posts: 13,095
    Personally I just spit on it and then wipe it with my tshirt before playing. I don't know why you guys get so crazy about record cleaning.
