Just joined
Hi, I just joined the forum
I have owned Monitor 5's in the past, and currently own a pair of Monitor 10's and a pair of RTA 12s
I purchased the 12's today, 04/16/22. They came with a cable that had what looks like a capacitor attached to them.
The 12's hey came with
Any help with what these cap looking things are is very helpfull.
Thanks all
Brian
  • Emlyn
    Emlyn Posts: 4,396
    edited April 2022
    Welcome! Those speaker cables are a model that Polk sold under the name “Cobra” a long time ago. Search on the forum or Google for “Polk cobra” and you’ll find a lot of info. The cables had high capacitance and presented problems to a small number of amplifiers when they were available. Personally I wouldn’t use them, even though they are a novelty, because there are better options.
    Those speakers look great!
  • boston1450
    boston1450 Posts: 7,497
    Agree. The hats look very nice
    Randy/Maine
  • Hermitism
    Hermitism Posts: 4,207
    Those speakers are beautiful, congrats on the purchase and welcome to the forum.
  • Gardenstater
    Gardenstater Posts: 4,209
    edited April 2022
    Welcome! The Polk Cobra cables are high capacitance, relatively high resistance, ultra-low capacitance cables that can give improved sound quality. That part that looks like a capacitor is probably a zobel network, which is a resistor in series with a capacitor and if placed across the + and - terminals of the speaker, will protect from any instability that a minority of solid state amplifiers can suffer from otherwise. They are Litz type cables made of magnet wire basically, and the weave gives the low inductance. Low inductance is very good. I remember the salesman offering me those cables when I bought my 7Bs in 1979 lol.
    I would prefer to use what I am using, which is a ribbon cable that is similar to the design of the Alpha Core Goertz cable. Also high capacitance. My Crown D150 has never had a problem with it, even without a zobel network.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    Tony M Posts: 11,026
    :pB)
  • Bzzzzzzt_pop
    Welp. I am certainly happy i came here to ask. So much information. Thanks everyone. I certainly do enjoy polk speakers
  • Gardenstater
    Lets see some *grilles off* pics :)
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Bzzzzzzt_pop
    Sure, no problem
  • Bzzzzzzt_pop
    I'm still trying to research which version these are. The serial number says 12, the crossover says 12, the tweeter is a SL1000.
    The white powdery substance I am going to try to just brush off with a soft brush. I should pull that driver and look behind it. Holidays get in the way. But family....
  • Gardenstater
    edited April 2022
    I'm pretty certain you have the earliest R.T.A. 12 but someone has replaced the Peerless tweeters with SL1000s. It may very well have been a warranty replacement and that is what Polk sent. They switched to their own SL1000 sometime in 1984 I believe. This is from Audio Apr. 1979:
    Audio Jan. 1980:
    Audio Oct. 1979:
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Bzzzzzzt_pop
    I suspect that too. It also looks like something bumped one of the tweeters as it is out of alignment, no big deal. I'll see about replacing the SL1000's. Would there be any reason the crossover would have been changed when this was done? Or can I safely assume the crossover wasn't modified?
  • Bzzzzzzt_pop
  • Bzzzzzzt_pop
    Is there a Left and Right to these speakers?
  • Emlyn
    Emlyn Posts: 4,396
    96dB efficiency is pretty remarkable for a Polk product. Built for rocking out in the basement but 120dB peaks can be painful.
  • Gardenstater
    You can see everything on the outside and everything looks bone stock to me. I feel safe in saying that you would prefer the sound of the Peerless, especially if you get a couple that are around 79 or 80 production years.
    Nope. Not with the early ones. Both of the midwoofers receive the same signal. In the later model they rolled off the outer driver at a lower frequency to counter the comb filtering/lobing issue.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Bzzzzzzt_pop
    I've tried everything short of re-caping the speakers. The SL1000 tweeters have got to be replaced in these RTA 12s. They sound like they're underwater. Sorry.
    xschop Posts: 4,747
    New caps and silk domes are in order.
  • Gardenstater
    These would be good, although they don't have the aperture tuning holes that Polk started putting in the domes at some point:
    https://www.ebay.com/itm/275286561227?hash=item40185b91cb:g:F7UAAOSwXMViZdLP
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    mhardy6647 Posts: 33,137
    may I just add: @Bzzzzzzt_pop is a great name! :)
    edited April 2022
    Welcome.
    Now unhook those wires on your speakers immediately!
    Each wire is supposed to remain separate. How you haven't blown anything is beyond belief.
    OK, I see now, :o . You're supposed to run 2 wires to the speaker, not one.
    You're supposed to have a + (red) and a negative - black channel wires. 2 separate wires.
    How in the world these are functional is a miracle.
    I see why your sound is underwater sounding. :s
    Get some regular speaker wire.
    pitdogg2 Posts: 24,652
    edited April 2022
    Tony M Posts: 10,310
    11:20AM edited 11:23AM
    Welcome.
    He has two wires there and they are FINE, Do some research !
    Post edited by pitdogg2 on
    OK.
    But how does one research something one doesn't know about? :s
    Maybe, just maybe, YOU could've named what wires those are!
  • Gardenstater
    Here's a lil more info. which I had meant to share. From Audio Aug 1977. They actually called it Polk Soundwire before the Cobra:
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Tony M wrote: »
    OK.
    They were named at the top of the thread with his first pictures. Try and keep up here big boy. 😉
    Polk Cobra cables.
    For someone who has "collected" sooo much audio gear I'm shocked SHOCKED I tell you, that this is the first you've heard of them. Even after you emoji'd George's answer to them once again at the top of this thread.
    Now you're up to speed!
    https://www.hifiengine.com/gallery/images/polk-‘cobra’-speaker-cable.shtml
  • rebelsoul
    rebelsoul Posts: 756
    Get rid of those speaker cables there garbage.
    Tony M wrote: »
    OK.
    Polk Cobra cables.
    Thank you.
    I appreciated and read the link you posted. B)
    I read about cobra cables here 20 years ago and have seen them mentioned here once a year or two maybe. I've forgotten how they were made. I even forgotten the first few posts showing the Polk name AND comments about Polk's cobra cable. :#
    Also, cables is not an area I have much knowledge of. I do have enough to buy OFC when ever I do. 14ga. or 12ga. is my size preferences. That's about it. :)
    My memory isn't what it was. :/ Something has happened the past 6 months or more. Maybe something has started. :'(
    Speakers, yes I've owned a lot and know a lot about how brands sounded, BUT, my memory is slipping away even on those.
    F1nut Posts: 49,880
    Welcome.
    Better have your eyes checked.
    Welcome.
    How many wire manufacturers weave the positive and negative wires together?
  • SeleniumFalcon
    SeleniumFalcon Posts: 3,530
    Actually the Polk speaker wire is the only Polk component to be listed in Stereophile's 100 most influential audio products. I'm not sure why it doesn't have a better reputation here on Polk's forum. I know Matt Polk used some on his LSi speakers on the treble connections. For dedicated audiophiles six pairs are paralleled to reduce the resistance for best bass.
    If you look at your amplifier's schematic and you see an inductor in series with the positive output it means the basic circuit is not comfortable with capacitive loads and the inductor was used to increase impedance at higher frequencies.
    ...I'm not sure why it doesn't have a better reputation here on Polk's forum...
    Pretty sure that was catalyzed by the folks who lost marginally stable amplifiers to it. ;)
    I had a friend in college who used it with a pair of Monitor 10s and a GAS Son of Ampzilla. That combination worked well and sounded excellent.
