[Monitor 10A] What is this crossover part?
Hello all. I'm about to proceed with a x-over upgrade on my Monitor 10As. I'm clear on everything except I have no idea what this large "spool" of wound copper wire is. Should I just reattach it when I finish installing the other components?
My current plan is to replace the caps, resistors, and binding posts, are there any other upgrades I should do "while I'm in there?"
Thanks in advance!
Best Answer
  • Gardenstater
    Gardenstater Posts: 4,804
    Answer ✓
    That is the large inductor (coil) for the Midwoofer drivers. If you don't re-attach you're not going to like the way they sound :)
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
Answers
    F1nut Posts: 52,011
    What do you mean reattach it?
  • F1nut wrote: »
    I was assuming I'd have to disconnect it to get under the PCB while I'm working on it
  • Gardenstater
    It is best to desolder the wire and re-attach when you are done with the XO work. I tried the other way and it just ended up stressing the wire and the solder joint, which had to be re-flowed, and it made the work more difficult.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 52,011
    Got ya. Just desolder the connection on the board. Do not cut the wire and do not unwrap it.
    Pinch the tops of the 4 standoffs with needlenose pliers one at a time to remove the board from them. Be careful with the standoffs as they can be a bit fragile.
