[Monitor 10A] What is this crossover part?
shellshox345
Hello all. I'm about to proceed with a x-over upgrade on my Monitor 10As. I'm clear on everything except I have no idea what this large "spool" of wound copper wire is. Should I just reattach it when I finish installing the other components?
My current plan is to replace the caps, resistors, and binding posts, are there any other upgrades I should do "while I'm in there?"
Thanks in advance!
Thanks in advance!
Best Answer
That is the large inductor (coil) for the Midwoofer drivers. If you don't re-attach you're not going to like the way they sound
George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Answers
What do you mean reattach it?Political Correctness'.........defined
President of Club Polk -
I was assuming I'd have to disconnect it to get under the PCB while I'm working on it -
shellshox345 wrote: »
It is best to desolder the wire and re-attach when you are done with the XO work. I tried the other way and it just ended up stressing the wire and the solder joint, which had to be re-flowed, and it made the work more difficult.George / NJ
iFi nano iDSD DAC
iPurifier3
Got ya. Just desolder the connection on the board. Do not cut the wire and do not unwrap it.
Pinch the tops of the 4 standoffs with needlenose pliers one at a time to remove the board from them. Be careful with the standoffs as they can be a bit fragile.Political Correctness'.........defined
