7.1 setup , need guidance.
I am setting up my dream home theatre setup. I have really worked hard on this.
I have purchased Denon X2700H, Polk RC85i front speakers, RC55i surround, R60i Atoms ,Sub HT-10. Room size 12 x 10, need advice and guidance on setup,settings and placement of them.
Answers
  • ken brydson
    ken brydson Posts: 9,020
    No center channel?
  • Polk Monitor XT35 Center channel.
  • rooftop59
    rooftop59 Posts: 8,120
    karthic816 wrote: »
    So basically you want the three mains (clr) to be as close to ear height as possible, and the center other directly above or below the screen. I would suggest using a crossover of 80hz, but run the audyssey and see what it recommends. For the atmos and surrounds I would consult the manual.
    Let us know how it sounds when it’s all set up: sounds pretty sweet!
    Game Room 5.1.4:
    Bedroom 2.1
  • Thank you, I got a rough idea where all the speakers.Placing the surround is the challenge now as its a in wall, I will be able to keep it as rear surround only. Any suggestions??
  • Kryten
    Kryten Posts: 79
    Congratulations on the robust home theater setup. I would start with
    https://dolby.com/about/support/guide/surround-sound-speaker-setup/
    You have a bit of flexibility on the placement of the sides and rears.
    Note that 7.1 is different than 5.1.2. The third number refers to height or atmos speakers. The Dolby site shows many example placements.
  • Thank you, that was a useful info. I am planning to setup 5.1.2.. and I dont have walls to support surround.. hence going for rear surround
  • gp4jesus
    gp4jesus Posts: 2,019
    edited April 2022
    Set up is key parallel to room acoustics. Watch this first…
    https://m.youtube.com/watch?v=0_pZXUf_5J4&list=PLQ4bUzhLn0LqXVCu2G9a12AVvmcYE9sQw&index=1
    EP 2 (or later) should get you other helpful episodes. He keeps it simple yet comprehensive. I think you should strive more for side surrounds than rears just as he illustrates.
    Enjoy. Tony
    *all connected w/Premiere ICs
  • Side surrounds are the best. In my case i use RC55i In wall speakers for surround and I dont have a proper wall on the sides(one side is a huge french window)
  • gp4jesus
    karthic816 wrote: »
    …one side is a huge french window)
    Plan to buy heavy drapes.
